RacerPartsWholesaleAdvanstarMotorcycleShowsSpringfield ArmoryTrident-Exhausts.comSportbikeTrackGearShopTriumph.comMotorcycle.comMotorcycle.com Classifieds!
Old 04-24-2006   #1 (permalink)
So, I brought my new '06 S3 home Friday night. I just managed to get home before the rain started. And of course, its been like a monsoon ever since, so I didn't get a chance to ride on the wekend. Yeah, I know the bike doesn't really exist until I post a photo here...-)
But I was trying to attach my tank bag straps yesterday. The front strap goes under the front tank mount. I tried to remove the front allen screw so I could raise the front of the tank. The allen screw was very tight, and I managed to turn it a couple of turns, but it feels cross-threaded. Is there a trick to getting this off ? Should it just unscrew ? Or is it safety wired or somehow clamped in place ?
thanks,
Rich
Rich_Williams is offline   Reply With Quote
Old 04-24-2006   #2 (permalink)
Favorite Bike: Triump Speed Triple (duh)
Other Motorcycle: 1999 Honda CBR600F4-track
I've taken the tank off of my '05 S3 a few times and there's nothing special about that screw in the front. It just screws out.
You do have to be careful about the other connections to the gas tank once you get that screw and the one in the back off. (if you're actually taking the tank off). There's a gas line connection and another tube connected to the tank of some sort.
2005 Speed Triple
1999 Honda CBR600F4 (track bike)
2003 SV650 (sold)
Kajota is offline   Reply With Quote
Old 04-24-2006   #3 (permalink)
If the 1050 is anything like the 955, you should have two breathers on the left side of the tank where it meets the frame, fuel in and out, fuel pump power cable, and your fuel level sensor cable on the bottom. If your bike is running strange after reconnecting the two breathers and/or your get a sucking noise every time you open your fuel tank after riding, you probably have them backwards.
Your front screw might be getting pushed on by the tank while you're unscrewing it. Make sure the tank is centered and isn't pushing on it. Otherwise, check the threads when you get it out to make sure the dealership or someone assembling the bike didn't cross-thread it. Underseat mount is easy.
Old 04-24-2006   #4 (permalink)
Good point. I'd add that undoing the back and side panel tank mounting screws, then slightly lifting/wiggling the tank from the rear might help release any tank-induced tension on the front screw.
[ This message was edited by: Curmudgeon on 2006-04-24 10:49 ]
Curmudgeon is offline   Reply With Quote
Old 04-24-2006   #5 (permalink)
And be careful you don't kink that breather !!! can create all kinds of issues....
ZARD Full stainless system, BMC Air Filter, DynoJet Powercommander,Pazzo Short Levers, Renthal Ultra Low Bars, Rizoma Fluid Reservoir, Oberon Bar-ends, Renthal 45T Rear Sprocket, Renthal 17T front Sprocket, AFAM Gold Chain, Triumph Hugger, Belly Pan !
gstar is offline   Reply With Quote
Gas Tank Removal graciejohn2 The Rocket Science Forum 10 10-06-2007 04:09 PM
help! - Gas Tank Removal Merrimac Speed Triple Forum 5 11-24-2006 07:22 PM
gas tank removal haggis95 Sprint Forum 4 09-26-2006 02:52 AM
my gas light is out after tank removal madmic Tiger Workshop 5 09-25-2006 11:53 AM
Tank removal....draining gas jdub3 Speed Triple Forum 13 05-14-2006 03:15 PM
