BikeBanditMotorcycle.comAdvanstarMotorcycleShowsSpringfield ArmoryRacerPartsWholesaleSportbikeTrackGearTrident-Exhausts.comMotorcycle.com Classifieds!
ShopTriumph.com
Old 04-22-2006   #1 (permalink)
Hi Guys,
Just installed my Matris M4R on my triple...
Haven't tested it yet but thought I would get these pics straight up on here...
From The front..
Closer !
Left Hand Side...
Right Hand Side..
Was dead easy to install.. Going out for a test ride now.. catch ya all laterz!!
ZARD Full stainless system, BMC Air Filter, DynoJet Powercommander,Pazzo Short Levers, Renthal Ultra Low Bars, Rizoma Fluid Reservoir, Oberon Bar-ends, Renthal 45T Rear Sprocket, Renthal 17T front Sprocket, AFAM Gold Chain, Triumph Hugger, Belly Pan !
gstar is offline   Reply With Quote
Old 04-22-2006   #2 (permalink)
Lookin good! Where did you bought that one and how much did it cost? I just got my new 06 S3 and it definitely needs steering damper. Cheap life insurance if you do a lot endo's.. :razz:
Something it gives for you, something it takes..
L4TUA is offline   Reply With Quote
Old 04-22-2006   #3 (permalink)
Got that bad boy from carpimoto in Italy. was quite expensive.. cost me 555 EUR ! ! ! plus shipping...
Old 04-22-2006   #4 (permalink)
Just been out for a test-ride... she seems to handle better.. much smoother through the tight turns on my favourite road...
Loving it !
Old 04-22-2006   #5 (permalink)
Gstar
Looks greats but have to say you boys down south got too much lolly....
MH
Skint Northerner
If it looks like an Aligator,
Walks like an Aligator
and
Bites like an Aligator.
It could be a Crocodile......
MonkeyHanger is offline   Reply With Quote
Old 04-22-2006   #6 (permalink)
Favorite Bike: 2005 Black Speed Triple
TonUp's Avatar
Other Motorcycle: 2007 Suzuki V Strom 650
Extra Motorcycle: 1974 BMW R90/6
Sweet! Very Clean installation. How does it feel?
Ton Up!
Bennington Triumph Bash 2009
TonUp is offline   Reply With Quote
Old 04-22-2006   #7 (permalink)
Looks a lot cleaner than it is ! !
Gouged up the outer leg clamp bolt.. just on the old over-tighten.... never know when to stop.. infact I managed to do it with my torque wrench.. easily drilled out if it shows any sign of movement...
It's a lot better than the LSL damper that I tried previously, I had the one which attached to the rocker cover, you have to use lock stops with it.. which I am not happy using to be honest...
The Matris is perfect for the job... feels great !
Old 04-23-2006   #8 (permalink)
HiVel's Avatar
Beautiful! I just put an LSL on my S-3 -hope it works as well as the Matris looks!!
Anything worth doing is worth doing to excess!
2007 Tiger "Old Blue"
HiVel is offline   Reply With Quote
Old 04-24-2006   #9 (permalink)
That Matris def looks better than LSL . Anyone experienced the one Jacklilley sells? extreme tech something, any good? I have never heard about that brand before?
Old 04-24-2006   #10 (permalink)
Favorite Bike: Speed3 -09
Martin_R's Avatar
Carpimoto also sells the entry/mid level M3 & M4 dampers in addition to the top spec M4R, when price is an issue.
Martin_R is offline   Reply With Quote
Matris Damper Review dblhelx Speed Triple Forum 29 01-04-2008 01:58 AM
MATRIS Damper Users dblhelx Speed Triple Forum 0 09-13-2007 03:41 PM
Matris Vendor Recommendation? dblhelx Speed Triple Forum 8 09-07-2007 07:11 AM
matris steering damper dieselgeek Speed Triple Forum 2 01-08-2007 10:59 AM
Install Matris Damper and LSL rear sets!! HiVel Speed Triple Forum 9 05-24-2006 07:18 AM
