AdvanstarMotorcycleShowsTrident-Exhausts.comBikeBanditMotorcycle.comSportbikeTrackGearSpringfield ArmoryShopTriumph.comRacerPartsWholesale
Old 04-22-2006   #1 (permalink)
05-06 S3 coming out of 1st under mid to high power
the bike is hitting neutral then a 2nd click and there 2nd gear.
All other gears are shifting great less of a click then from new
the bike has 2300 mi on it and I shift alot with the back roads
I ride. It seems to be the bike and not me I think.
(I know it's a poor musician that blames his instrument)
P.S. this is the best bike I have ever had. :chug:
f1eric is offline   Reply With Quote
Old 04-22-2006   #2 (permalink)
Favorite Bike: Speed3 -09
Martin_R's Avatar
Check the gear change linkage for play and reassemble if necessary. Many 1050s seem to come out of the assembly with loose linkage joints and/or gearbox end lever. Most likely this is the reason behind your dropping into neutral too. Especially the front balljoint ball seems to come undone quite easily unless assembled with plenty of blue loctite on the threads.
Do a search on this forum, and you will find plenty on the subject.
Martin_R is offline   Reply With Quote
Old 04-22-2006   #3 (permalink)
I also adjusted my gear lever down. It was at a point where I couldn't easily raise my foot easier. So, I would sometimes make sloppy/soft shifts because it just wasn't in the natural range of my ankle pivot.
DwarF is offline   Reply With Quote
Old 04-22-2006   #4 (permalink)
In many cases the gearboxes are a bit stiff on new bikes and will get much better when the kms add up.
HarriS is offline   Reply With Quote
Old 04-22-2006   #5 (permalink)
Martin_R's Avatar
Good catch. Mine was also originally in a position, where on upshifts the gear lever would catch on the rearset support.
Old 04-22-2006   #6 (permalink)
Favorite Bike: 2005 Black Speed Triple
TonUp's Avatar
Other Motorcycle: 2007 Suzuki V Strom 650
Extra Motorcycle: 1974 BMW R90/6
Great Advice Martin & Dwarf! I noticed a little rough shifting, will check the lever this week.
Thank you!
Ton Up!
Bennington Triumph Bash 2009
TonUp is offline   Reply With Quote
Old 04-23-2006   #7 (permalink)
I will be checking it out.
thanks!
Old 04-23-2006   #8 (permalink)
As did I. It made all the difference in the false neutrals for me and took 5 minutes to adjust.
Capt.
Captain_Rat is offline   Reply With Quote
77 Bonne -- Bogg Down in 2nd 3rd gear tokarz33 Classic, Vintage & Veteran 4 12-08-2006 03:24 PM
2nd Gear Shift When Cold DavidoWesto Speed Triple Forum 9 11-04-2006 09:27 AM
Wheelies in 2nd gear Jglisso Speed Triple Forum 4 10-29-2006 04:32 PM
2nd gear wheelie buggy Club Cafe 14 06-25-2005 11:43 AM
05-S3 2nd Gear Wheelie? bikeordie Speed Triple Forum 17 05-28-2005 09:23 AM
