RacerPartsWholesaleMotorcycle.comSpringfield ArmoryMotorcycle.com Classifieds!AdvanstarMotorcycleShowsBikeBanditShopTriumph.comTrident-Exhausts.com
Old 04-22-2006   #1 (permalink)
Favorite Bike: 2004 S3--black
FelixLeiter's Avatar
Location: Where the oil comes from...no, not over there
I installed the aluminum bushing end of my new Skyking front engine mount sliders the other night. Removing the old engine bolts shows that there is a nut with a large flange attached on the back side and a bolt with a washer on it on the outside of the bike. The Skyking sliders came with one washer (per slider) but the instructions didn't say where it went...
...since the oem nut has a large flange and the Skyking bolt doesn't I installed the washer on the nut side (inside) in order to "make up for" the lack of a flange. I figured that the large aluminum bushing on the outside of the slider will make up for the lack of a washer. Plus, without a washer on the outside of the engine between the frameslider and the engine mount the frameslider has as larger contact patch with the engine mount hole. Anyone have any insight? Am I making mountains out of molehills.
Yr Fthfl Srvnt
FelixLeiter is offline   Reply With Quote
Old 04-22-2006   #2 (permalink)
Good to go on the install if you put the washer on the nut side of the mount. The washer should be there to protect the mount while the nut is spinning on (slider side shouldn't be spinning, eh?) and tightening down, and evenly distribute the force so the nut doesn't sink down into the aluminum.
You of course used a torque wrench to make sure you weren't overtightening things, right?
Old 04-24-2006   #3 (permalink)
Other Motorcycle: Duc999/S3/D650
Why not ask John King?
Billybob
Billybob is offline   Reply With Quote
Old 04-24-2006   #4 (permalink)
Favorite Bike: 2005 Black Speed Triple
TonUp's Avatar
Other Motorcycle: 2007 Suzuki V Strom 650
Extra Motorcycle: 1974 BMW R90/6
Mr. King is very prompt. I like the way he takes care of his customers.
Ton Up!
Bennington Triumph Bash 2009
TonUp is offline   Reply With Quote
slider install sodapop Sprint Forum 1 06-29-2007 10:36 PM
Help with skyking slider install? Can't reach rear bolt mperetz Speed Triple Forum 17 04-20-2007 12:42 AM
Frame Slider install, Torque anyone? TommyV Speed Triple Forum 1 01-25-2006 08:01 PM
SkyKing frame slider (bobbins) Gearloose Tiger Chat 1 04-28-2004 03:23 AM
Skyking Frame Slider Tiger Chat 8 11-19-2003 11:57 AM
