First impressions of the
TechSpec tank grip panels I just installed.
First of all, Dean at TechSpec was very helpful and responsive when there was a problem with my credit card. Note that it was my mistake, not theirs. Once the credit card problem was solved (late in the day) the product shipped the next day and was here in 4 days. I expect it would have been shipped the same day if I had called in the morning.
I chose the Snakeskin pattern, and it is an interesting match with the seat fabric. Some of the pictures don't do it justice. It's very grippy, but without being snaggy. I'm not sure if I like it yet, but I'm giving it a chance. There are several other choices.
The quality of the general sheets that I used to cut the side panels was very good. However, the buckle guard/tank pad was less so. I don't know how they cut them but some of the diamonds had edges broken off them in the process. I think I'll replace it with something else later.
I made paper patterns, and altered them until I got what I wanted. Cutting the material with scissors was fairly straightforward, but this is probably not the best method. If I did it again I think I would pin the stuff down to a board and use a sharp knife of some kind. Scissors left small bits of the white backing paper stuck to the edges and it was very hard to remove.
The directions recommend using a grinder or rotary tool to chamfer the edges. I didn't do so, but after installation I think it's a good idea. I'll have to remove them and do that later. The tank pad/buckle guard comes that way, and I tried it with a bit of remnant. It's easy.
The adhesive is the great thing about this product. You can easily remove the panels and re-stick them if they aren't in the position you want. It actually
doesn't leave residue on the bodywork and if you stick it on some waxed paper it will be fine until you want to re-apply it. Technically a good and versatile product. Note: The adhesive will remove easier if it's warmed up with a hairdryer or something.
I haven't had it on the road yet because it's pretty rainy and nasty today, and I'm just getting over a cold. First impression is I like them very much. More to follow.
http://techspec-usa.com/index.html
[ This message was edited by: crashmasterd on 2006-05-29 08:35 ]
