how to disconnect light for trackdays? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-14-2006, 07:10 PM   #1 (permalink)
tried taking out the fuse-- the bike won;t start without the fuse!! must be wired through the ignition circuit, which is rediculous cause if you blow the light fuse, the bike will die
salty_scuff is offline   Reply With Quote
Old 04-14-2006, 11:48 PM   #2 (permalink)
I wound up taking the friggin' headlight lenses out and unplugging the bulbs. In hindsight I should have put about 10 layers of tape over the lights, would have been lots less trouble. You'll also run into the same problem with the taillight. I'd try the tape solution first-as long as they can't see any light shining through they'll probably let through tech inspection. Have fun!!
auraaura is offline   Reply With Quote
Old 04-14-2006, 11:52 PM   #3 (permalink)
I take out the fuse for the tail light and remove the headlamp globes. I remove the headlamps so the bulb filaments won't be damaged by excessive vibes (don't know if it helps though).
02S3 is offline   Reply With Quote
Old 04-15-2006, 01:11 AM   #4 (permalink)
Favourite Bike: 2003 Triumph Speed Triple
You guys don't have a plug for the tail light and connectors for the signals? I can just unplug mine with the black connector. Don't have to screw with tape or anything.
Disconnect Headlight stinger Sprint Forum 1 05-25-2007 09:05 AM
Racing Suits for Trackdays toesnose Daytona Deliberations 4 11-30-2006 10:46 AM
Oil leak/trackdays chitownG60 Triumph SuperSports 3 07-21-2006 02:18 AM
How do i disconnect PC-III glw The Rocket Science Forum 12 04-19-2006 07:03 PM
Anyone riding trackdays next weekend at Jennings, FL? YYZSKI Daytona Deliberations 0 02-11-2006 11:33 AM
