Exhaust Wrap - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismMotorcycle.com Classifieds!SportbikeTrackGearHonda Powersports
Old 04-13-2006, 02:35 PM   #1 (permalink)
Anyone ever use that fiberglass tape some people use to insulate their exhausts? As it gets warmer around here, my right heel is getting cooked from proximity to the pipes. I figure some of that heat tape would probably do the trick as well as looking pretty badass.
Any downsides? I imagine it might trap water, but it would get boiled off every time I run the bike, right?
gr8shandini is offline   Reply With Quote
Old 04-13-2006, 04:38 PM   #2 (permalink)
Favourite Bike: 2003 Triumph Speed Triple
My buddy with an XB12 wraps black header tape around his headers and exhaust and says nothing bad has ever happened. Its just a PITA to have to rewrap when he does exhaust work.
Old 04-13-2006, 04:49 PM   #3 (permalink)
I'd probably only do the stuff aft of the header back to the cans and leave a small gap for the O2 sensor. The only time I'd see myself having to bust that apart is if I decided to go for a full system.
On a technical note, how does he secure it? I don't imagine that there's any adhesive on it. Do you just pull it tight, tie it off, and hope for the best?
Old 04-13-2006, 05:02 PM   #4 (permalink)
Some stainless wire leftover from your racing days, twisted with the seldom used tool, is how I've seen it finished. I've never used the wrap, personally. Is it put on wet like the exhaust repair tape I used on rusty Cleveland cars in high school?
realizations is offline   Reply With Quote
Old 04-13-2006, 05:08 PM   #5 (permalink)
Pretty sure he puts it on dry and wraps it really tightly. I'd have to check to see if he uses wire or hose clamps.
Old 04-13-2006, 08:52 PM   #6 (permalink)
if you put the tape on wet its alot easier(dry it puts off alot of fiberglass type dust).i know that on carb. bikes you sometimes have to rejet after taping, i know i had to.and because the pipes retain so much heat the life of your pipe is often shortened.
lofathd is offline   Reply With Quote
Exhaust wrap Spendthrift Speed Triple Forum 4 04-18-2007 09:54 AM
Exhaust Wrap JKDJose Twins Technical Talk 5 04-13-2007 05:48 PM
Exhaust Wrap Lee The Rocket Science Forum 9 12-13-2006 08:25 PM
exhaust wrap ditchrat69 Triumph SuperSports 4 03-07-2006 02:53 AM
Exhaust wrap RedABSrider Maintenance & Workshop Talk 7 11-07-2005 07:16 PM
