Side stand and bolt I powder coated. The Hagon instructions suggest 40 Nm plus Loctite for the shock bolts.
However the Triumph shop manual shows 48 Nm for the top
and 100 Nm for the bottom. David Quinn Inc return my E-mail
VERY promptly stating that the instructions were a generic
suggestion and that i should follow the manual but use lotite.
I try not to reuse loock fasteners but no local sources
had 10M and 12M 1.25 thread nuts. the stockers still
had the tangs so I used them at factory torque specs
but did use Lotite blue and lithiium grease for friction
surfaces. The painted a red line on each nut to thread
to make it easy to check nut stability.
