Motorcycle.comBikeBanditMotorcycle.com Classifieds!Springfield ArmorySportbikeTrackGearTrident-Exhausts.comRacerPartsWholesaleAdvanstarMotorcycleShows
SportbikeTrackGear
Old 04-12-2006   #1 (permalink)
Just installed my silver RIZOMA brake reservoir and boy was it easy!!! :chug: Took a total of 15 min. and the brakes were just way they were when I started ! Except better looking! I will try to post some pics of all the mods I've done when I get chance.
bubble is offline   Reply With Quote
Old 04-12-2006   #2 (permalink)
Hey bubble, I just bought one myself. Did you bleed the line and start new?
Can you give me an idea on the details of your fast process? I would like to put it on before the weekend.
Kravr36 is offline   Reply With Quote
Old 04-12-2006   #3 (permalink)
I did a thorough bleed on mine just to be safe when I switched out to a Rizoma res.
Old 04-12-2006   #4 (permalink)
Did you use a pump or drain the old and pump the new in via the brake lever?
Old 04-12-2006   #5 (permalink)
I use a pump, compress the calipers a couple times, keep pumping until I see no bubbles, then I do the baby bottle for a res full or two just to be sure. Makes for excellent braking.
I'm amazed that my EBC Double H pads still have a good amount of meat on em after 6,000 miles of hard braking and stoppies...
Old 04-12-2006   #6 (permalink)
Kuhlka, who is a good supplier of EBC HH pads??
TrackerOldGuy is offline   Reply With Quote
Old 04-12-2006   #7 (permalink)
Hrmmm, well I've gone with my local HondaKawaYamazuki dealer for pads and sprockets, but I have a link here somewhere of a place I went to look up part numbers...
Old 04-12-2006   #8 (permalink)
For UK I found this place;
B&C Express
NewSpeed3 has a pretty good price on the equivalent Carbone Lorraine pads for the 1050.
Otherwise, Cycle Brakes has a complete listing of all the parts, so I assume you could give them a call and get em from there in the USA pretty easily. I think thats where I originally found the EBC pdf showing me which part numbers I needed to give to Hondaeast to order my pads. I have a discount there through my local bike club (Toledo Sport Bike Riders).
EBC complete parts catalog PDF. (3meg file)
Old 04-12-2006   #9 (permalink)
swapped my tupperware for a Rizoma (PJsParts) a couple of weeks back - didn't bleed the brakes. Dumped the old reservoir, installed new one, filled, squeezed the hose "link" to push out the air. As long as you DON'T squeeze the front brake lever with the reservoir disconnected, you shouldn't need to bleed. Good luck!
vinny
Be nice to America or we'll bring democracy to YOUR country...
vinnyf is offline   Reply With Quote
Old 04-12-2006   #10 (permalink)
vinny is right. I just make it a habit to bleed my brakes regularly just in case. With the way I ride my bike, an inopportune pocket of air would cause a real big problem, lol.
What brake fluid reservoir should i get???? Rizoma ? gsg? 24gt Speed Triple Forum 15 05-04-2007 01:58 PM
Rizoma Front Brake Reservoir boboso Twins Technical Talk 9 10-05-2006 08:47 PM
Rizoma brake fluid reservior GSJazz Modifications & Workshop Talk 5 06-01-2006 12:17 PM
RIZOMA Brake resavoir size? bubble Speed Triple Forum 9 02-26-2006 06:46 PM
Rizoma brake resevoir nissn1 Speed Triple Forum 4 12-27-2005 03:37 AM
