Originally Posted by s2kf4isabre
Awesome, thanks for the feedback. I guess I might as well get around to doing this, or at least inspecting the filter, when I change my plugs out pretty soon
The fuel filter is a solid can of aluminium. Can one inspect such a thing without cracking it open?
I'll be sure to pick up a gasket to go along too
Probably a good idea. The service manual recommends to replace pump mounting plate rubber gasket every time you remove plate. I have, however, successfully reused the same gasket at least 4 times. It's just a sturdy large rubber O-ring.
But it's your ass in the cooker if the plate leaks, so: your bike, your call.
Edit. One more tip: the old filter is probably under fuel pressure when you remove the hoses. Best use a rag or you'll get fuel all over your face.
