On 2006-04-09 11:50, st-badge wrote:
Hi, can anyone tell me if you can get mirror extensions for the 05 speed triple.
Jack Lilley. And as said above, they do look like *****. I do not understand why they did not just make some longer stems, but instead decided to machine the huge bulky extenders.
If you do not mind the shape of the stock mirrors (I kind of like them):
-machine new longer stems, the stems are just a bent piece of steel(?) with a M10 thread on the mirror end and a few holes on the other
-if machining is not your thing, try to find some cheapo mirrors with longers stems of the same diameter and replace the stock stems with these
-you can also bend the stock stems in a vice so the mirros sticks further out and adjust the mirror end thread so that the mirror ends a few cm outwards
