RacerPartsWholesaleMotorcycle.comSpringfield ArmoryMotorcycle.com Classifieds!AdvanstarMotorcycleShowsBikeBanditShopTriumph.comTrident-Exhausts.com
Old 04-09-2006   #1 (permalink)
Chaz955i
Any tips on replacing the rear brake pads? I took out the two pins that hold them in but couldn't figure out how to get the inside pad out or for that matter retract the piston. Does the caliper need to be taken off the carrier for this? Any help is appreciated.
Old 04-09-2006   #2 (permalink)
Yep, you'll have to take off the caliper to change out the pads. One of them has a notched tab sticking off to one side which keeps them from coming out with the caliper on.
Old 04-09-2006   #3 (permalink)
Chaz955i
Thanks K. One more question. I'm assuming to remove the caliper I just take out the two 14mm bolts?
Old 04-09-2006   #4 (permalink)
That should do it as far as I can remember. I'm due for a new set of pads this spring. I'll probably throw them on before the Dragon in early may as well as a fresh set of rubber.
Rear brake pads pomallon Tiger Workshop 11 04-09-2007 04:53 AM
rear brake pads (06) jthursby Sprint Forum 5 01-14-2007 01:40 PM
Rear brake pads richb Twins Technical Talk 7 10-27-2006 11:34 AM
Rear brake pads RandyDTFR Club Cafe 1 03-08-2006 02:22 PM
Rear brake pads Jimi_X Twins Talk 10 09-27-2005 03:06 PM
