Cheers, Kevin,
Well, the newer S3 is "improved" in that they no longer put calibrations on the temp gauge, but I had a scanner plugged into my diagnostic port the other day - at idle, the temp climbed to around 206 degrees Fahrenheit, when the fan kicked in. The temp then stabilized around 206-210. I believe you're right - 219 seems kind of high, but not obscenely so. I'd check the thermostat, make sure the fan is coming on at the right temp, and that there are no air bubbles in the system - you know, all the normal stuff. Generally, overflow tanks run around 1/4 to 1/2 full. Good luck!
Be nice to America or we'll bring democracy to YOUR country...
