After very close inspection I am 99.9% certain that the leak is from the neutral switch, I removed the sprocket cover and no oil there, and it is too high to be from the sidestand bolts. Have removed the switch, wiped the whole area clean (oil around the switch is clean so no 'travel' contamination) put a smear of blue Halimer sealer on the threads and have reassembled it. Not been able to try it yet as the heavens have opened and I dont have any 'water wing armbands' to keep me afloat.
Thanks for your suggestions though, it gave me a few areas to check that I may not have.
.GNOME.
Tell me - as an \'outsider\' what do YOU think of the human race?
