Oh as a follow up, the SonyEricsson w800i is fully bluetooth enabled and will work with just about any bluetooth headset I've come across I'm not so certain about the media player portion working over bluetooth though, never tried it.
A note on the Nokia 8800, happen to also have the 8801 (the U.S version of that phone (my other account)) and it also have a media player and fm radio but it has a fixed amount of internal memory and will not hold as many tunes as a unit like the SonyEricsson will as it has a memory stick Duo slot. The Nokia uses a prior version of the symbian OS, the same as the 6230 phone and I think it's a wonderful version of the os that keeps the best balance I've found on keeping the phone behaving more like a phone and less like a handheld computer which I think many manufacturers miss when making smartphones, but that earlier OS isnt as fully featured in it's bluetooth implementation as a more current version of the symbian OS (Nokia 6680 and N-series for example) so I've found the Nokia a tad finnikey when needing it to connect and synchronize with the computer and it also will not connect with more current products (like Tom-Tom and Garmin Gps units w/ built in Bluetooth) that require a bluetooth 2.0 implementation. If does seem to work fairly well with headphones and a non-issue between handhelds and other cell phones though. A great phone over all, quite the looker, poor battery life, occasional freezes as is my experience though (same small nagging traits as the 6230 all in all w/ regard software), all said one of the best all round phones I've ever had. Nobody beats Nokia for it's address book implementation (well maybe windows smartphone 5), SonyEricsson still only has a limited address book with the standard phone, fax, email account, I'm the kinda guy that needs it all including your full mailing address, notes, reminders, etc. and the Nokia does all that and then some.
The implementation of the media player and radio are very phone like though, and you'll have to navigate the menu and turn those on or like I did set it up as a voice command to turn on and off.
The Sony Ericsson is the best implementation of the media player/FM tuner feature I've come across, there is a dedicated button that activates the media player/fm tuner and the controls to navigate are dead simple and intuitive to use while riding even. It behaves like a true MP3 player when in that mode, the battery life is pretty impressive also, esspecially when compared to the Nokia 8800 (which is why it comes with 2 batteries in the package).
If your an active kind of guy and am thinking about using it on the bike w/ gloves on I'd strongly advise you to take a look at the SonyEricsson, if your a walking/working kinda guy the Nokia will do nicely as you do need more visual and tactile involvement when using the phone (keys are kinda smallish and you'll likely use your fingernail to operate the nav keys), not the case with the SE. I'm also pretty certain that the ability to listen to media/radio over bluetooth with the Nokia is a no go as well, and it's earpiece doest give you the flexibility and freedom of choice that the SE does also, it also needs the earpiece to serve as the FM antenna.
sorry for the looong windedness. :-D
