RacerPartsWholesaleAdvanstarMotorcycleShowsSpringfield ArmoryTrident-Exhausts.comSportbikeTrackGearShopTriumph.comMotorcycle.comMotorcycle.com Classifieds!
Old 03-28-2006   #1 (permalink)
I have an '03 S3 and here are symptoms:
While at a pretty good lean, the bike will suddenly dive further in to the corner, in a bad, scary kind of way.
Also, between approx. 30 and 40 MPH the bike does not track straight and I experience a slow weave.
I checked tire pressure and suspension settings (stock). Both are fine. Tires are in good shape.
I also have a leaking fork seal.
Could i be experiencing a spent headstock bearing - and could this be the result of some rough wheelie landings (by prior owner - not me)?
I dig your hair-do
tstacy is offline   Reply With Quote
Old 03-28-2006   #2 (permalink)
It sounds like there might be more than one problem. The first and MAJOR problem is that if you folk seal is leaking it is blown and needs to be replaced (do both and not just the one). That in its self will cause the bike to handle bad. The second problem could be that the front tire is "cupped". That means the cords in the tire are coming seperated. The most commom way that happens is lot and lots of wheelies, or very rough roads/potholes or running to low of air pressure.
TonUp wrote:
Are you a Hooligan? I know that Corners and Cheapbastard are for sure and so am I!!!
http://i56.photobucket.com/albums/g1...-hooligans.jpg
corners is offline   Reply With Quote
Old 03-28-2006   #3 (permalink)
Favorite Bike: 2005 Black Speed Triple
TonUp's Avatar
Other Motorcycle: 2007 Suzuki V Strom 650
Extra Motorcycle: 1974 BMW R90/6
One quick way to check the head bearing for damage is to listen for a slight CLUNK noise when applying the front brake during a normal stop. If it's that loose you will hear it right away.
I agree with corners, replace both fork seals, which seal is leaking? Right side? sometimes if your bike sits for long period of time leaning right on the side stand this symptom will occur. I would try a center stand or a Pitbull stand, someway to equalize the pressure on both seals.
Most likely it was the previous owner, that bastard wheeling popping animal!!!! LOL!
Ton Up!
Bennington Triumph Bash 2009
TonUp is offline   Reply With Quote
Old 03-28-2006   #4 (permalink)
Heh, sounds like a good excuse to do a USD fork swap, hehe.
Old 03-28-2006   #5 (permalink)
I would disagree with the cupping thing... Cupping a pretty normal overall and if severe, the Corners is right. If it is severe you have some serious tire issue. Cupping is generally caused by braking style and how the tire deforms under braking loads. I digress...
The fork you are running is shot. ALL of the sysptoms you describe are that of a shock that is blown. Needs fixed ASAP... And yes, wheelies with a hard come down can definately blow a fork.
Isn't that Special...
Geof3 is offline   Reply With Quote
Old 03-28-2006   #6 (permalink)
Last time i checked.......yep the kickstand is still on the left side :hammer:
Robert W.
RbtWbbr3044 is offline   Reply With Quote
Old 03-29-2006   #7 (permalink)
So, i should move the kickstand to the other side? lol
Thanks for the input folks...
Let it be said I have nothing against wheelies... just poorly performed wheelies on MY bike. But then again... i went ahead and bought the thing anyway...
I've cupped many things in my day and some of those things were tires - this tire is worn beautifully and remains un-cupped. Nor is it particularly squared off.
BUT - I'll replace both fork seals and continue futzing with the head bearing. For the record, it is the fork seal on the opposite side of the kickstand (left or right, depending on where you're looking at it from)
Shot Forks though? Fooock...
I dig your hair-do
Old 03-29-2006   #8 (permalink)
TonUp's Avatar
If you live in Vermont it doesn't really matter what side it is on!
I will explained my theory to you in person next time we meet! It does make a difference.
Ton Up!
Old 03-29-2006   #9 (permalink)
Moderator
Favorite Bike: 2006 Tiger
miker's Avatar
Other Motorcycle: 1982 Harley "Sturgis"
Extra Motorcycle: 1986 XR 200
It could be your head stock bearing, but something else you may want to check is the swing-arm bearing and all the associated connections to the frame for the swing arm. Get a good grip of the rear wheel and shake it, see if it moves or clunks.
Might also want to check the run out of the wheel bearings, hard landings may have worn them prematurely.
I doubt it's your fork seal.
Mick
My Album
miker is offline   Reply With Quote
Old 03-30-2006   #10 (permalink)
Mick
Mike, he's got a leaky seal at the minimum. Depending on how the thing was set-up, the fork could have a blown cartridge or something. Given the way his fork is NOT operating, I would guess the fork has some problem. The wheel bearings are definately worth looking into as well.
If the headbearing were THAT shot you would be able to make it slap around by simply putting on the front brake and rocking the bike back and forth.
Daytona damage Pinballer Daytona Deliberations 7 12-03-2007 01:20 AM
What should I do with my crash damage? SR1 Sprint Forum 2 03-13-2006 09:50 PM
flood damage watch_this Classic, Vintage & Veteran 3 01-26-2006 12:39 PM
trophy damage rskeenan Trophy 4 04-17-2005 04:44 PM
Damage limitation Tiger Chat 2 09-10-2004 06:46 PM
