ShopTriumph.comSportbikeTrackGearMotorcycle.com Classifieds!Trident-Exhausts.comMotorcycle.comAdvanstarMotorcycleShowsBikeBanditRacerPartsWholesale
Old 03-18-2006   #1 (permalink)
What is best for keeping clutch cable lubed?? Grease or oil? Any pref.?! :hammer:
bubble is offline   Reply With Quote
Old 03-18-2006   #2 (permalink)
Favorite Bike: '01 Speed Triple
Cable Lube, with adapter is the best way that I know of.
Speed3 is offline   Reply With Quote
Old 03-18-2006   #3 (permalink)
Moderator
Favorite Bike: '06 Graphite 675
TripleThreat's Avatar
Extra Motorcycle: '06 675 Track Tool
Order one of these kits from somewhere...
The Kit contains one 6.25 ounce aerosol can of Champions Choice Cable Life and one Champions Choice Cable Luber (NEW improved design now accepts larger cables up to 3/8 inches in diameter. Two screw clamp for a tighter, more secure fit).
You can order one from Murphs Kits for $17.00. You can of course also find this stuff at a local motorcycle dealership or accessories retailer.
TripleThreat
NESBA "A" #719
On the Road Less Traveled...
...You Always Meet More Interesting People
TripleThreat is offline   Reply With Quote
Old 03-18-2006   #4 (permalink)
I got a cable lube tool from Targa and use white lithium spray. Works great, but make sure to put a rag on both ends to keep the ***** from spraying all over the place.
Old 03-18-2006   #5 (permalink)
Cable Life is the stuff I was thinking about, and works great!
Old 03-20-2006   #6 (permalink)
Thanx will do!!!
clutch cable lube? aprophet Classic, Vintage & Veteran 4 01-06-2008 04:20 PM
Cable lube chedd Twins Technical Talk 9 01-01-2008 07:22 PM
Clutch cable lube? Matrix04 Twins Technical Talk 1 01-10-2007 07:36 PM
need step by step advice on how to adjust/lube clutch cable PtboSprintSt Sprint Forum 2 06-06-2006 04:01 PM
Cable Lube Question Modifications & Workshop Talk 17 06-19-2003 04:11 AM
