Hex key size of 1050 front calipers? - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!New BonnevilleSportbikeTrackGearOntario TourismHonda Powersports
Old 03-14-2006, 10:31 AM   #1 (permalink)
Favourite Bike: Speed3 -09
Martin_R's Avatar
Looking for the hex key size of the 1050 S3's front caliper bolts.
My bike is winterized at a group garage and I will have to buy the proper hex head on the way. If only I could remember even the ballpark of the bolt.
[ This message was edited by: Martin_R on 2006-03-14 08:32 ]
Martin_R is offline   Reply With Quote
Old 03-14-2006, 10:41 AM   #2 (permalink)
I want to say it's a 6mm hex, but once I get home(in about 4-5 hrs), I can let ya know for sure.
6485 is offline   Reply With Quote
Old 03-14-2006, 01:16 PM   #3 (permalink)
Home sick today, so I checked. Of the visible bolts on the caliper, there seems to be three types:
(1) The two large bolts that hold the caliper to the bottom of the fork leg = 8mm
(2) The four bolts that hold the two halves of the caliper together = 6mm
(3) The bolt in the middle of the caliper that holds the "guide" along which the two brake pads move = 5mm
Sorry I don't know the technical terms. Hope this helps!
One day I got pulled over for speeding. The cop said, "don't you know the speed limit is 55 miles per hour?" I said, "yeah, I know...but I wasn't going to be out that long." - Steven Wright
Eldercanuck is offline   Reply With Quote
Old 03-14-2006, 09:35 PM   #4 (permalink)
I want to know who has any other bolts in the front calipers. Mine are a black 14mm hex and the bolts are total SH!T... They seem to be a cheap galvanized bolt as they are very rough. They f-ed up one of my mounts and it will require either a replaced front shock lower or a threaded insert. I want to use the hex bolts as seen in the factory pics...
Who else has the hex bolts??
Isn't that Special...
Geof3 is offline   Reply With Quote
Old 03-15-2006, 02:55 AM   #5 (permalink)
Martin_R's Avatar
Thanks guys, you have saved me an extra trip to the garage.
Geof3,
what bolts are you talking about? The main 2 caliper to fork mounting bolts? I do not remember any galvanized black bolts anywhere. The largest bolts around the caliper are the main mounting bolts and they are polished steel with a hex head.
Old 03-15-2006, 07:01 AM   #6 (permalink)
ES3
These are mine Nissin calipers on my S3 05:
No more Triumph
ES3 is offline   Reply With Quote
Old 03-15-2006, 07:04 AM   #7 (permalink)
Looks the same as mine. Wouldn't they be the same on all S3's???
Old 03-15-2006, 07:12 AM   #8 (permalink)
ES3
I think so. That's why I posted this pic. But I don't understand the question about the black 14mm hex bolts Geof3 is talking about :???:
No more Triumph
Old 03-15-2006, 11:12 AM   #9 (permalink)
I've got hex bolts on my '06 rather than the allens.
Avi8or is offline   Reply With Quote
Old 03-15-2006, 12:46 PM   #10 (permalink)
Obviously they have performed some cost cutting "upgrades" on the 2006 model. Those tapered head allen bolts look expensive custom made ones.
HarriS is offline   Reply With Quote
'06 front axle hex size? tsc17 Speed Triple Forum 5 07-25-2006 04:52 PM
Front Brake Calipers BluffRider T3 Sport / Touring Forum 2 05-07-2006 10:04 AM
What size hex key? Avatar Hinckley Classic Triples 9 04-15-2006 09:57 PM
Front calipers on 03 s4 timyjimy Triumph SuperSports 5 07-11-2005 12:37 AM
