ShopTriumph.comRacerPartsWholesaleMotorcycle.comBikeBanditTrident-Exhausts.comMotorcycle.com Classifieds!Springfield ArmorySportbikeTrackGear
Old 03-15-2006   #11 (permalink)
These black bolts are absolute garbage. I haven't messed with mine after my little "mishap" The bolt literally destroyed the lower mount on the way OUT... It is almost as if it were crossthreaded to begin with. The bolts are NOT polished and the rough surface causes significant gauling which destroys the soft aluminum of the lower. 06 owners beware, and be carefull that the bolt is ABSOLUTLEY coming out slowly and with little force. If it feels sticky at all, the lower is trashed...
Here's mine...
Isn't that Special...
Geof3 is offline   Reply With Quote
'06 front axle hex size? tsc17 Speed Triple Forum 5 07-25-2006 04:52 PM
Front Brake Calipers BluffRider T3 Sport / Touring Forum 2 05-07-2006 10:04 AM
What size hex key? Avatar Hinckley Classic Triples 9 04-15-2006 09:57 PM
Front calipers... Rocket-tre The Rocket Science Forum 9 08-25-2005 03:58 AM
Front calipers on 03 s4 timyjimy Triumph SuperSports 5 07-11-2005 12:37 AM
