Motorcycle.com Classifieds!SportbikeTrackGearSpringfield ArmoryShopTriumph.comAdvanstarMotorcycleShowsMotorcycle.comRacerPartsWholesaleTrident-Exhausts.com
SportbikeTrackGear
Old 02-23-2006   #11 (permalink)
I've got the Pit Bull one arm reversible and it has two pins, one for the left side and one for the right.
Brodie is offline   Reply With Quote
Old 03-17-2006   #12 (permalink)
folmonty
Thought I was going crazy on this. Just went from a 97 T509 to an 06. Same fit issue. Was making me crazy! Will grind that lip off inside of the axle. Pin goes in nicely about 20 mm then stops. Thanks for this post and related comments! :evil:
Old 03-17-2006   #13 (permalink)
I had the same issue- it turned out to be brown crud inside the axle- that smells like plastic when I Dremel it, but comes out pretty easily.
Standard pit bull pin worked fine after that.
"Nothing is ever what it seems but everything is exactly what it is." - B. Banzai
Rubbus is offline   Reply With Quote
Pit Bull front stand - OK to use on my Tiger? Soupamoto Tiger Workshop 2 01-04-2008 05:14 PM
Can the Pit Bull Stand Be Used With the TBA? Tiglath Twins Technical Talk 6 10-09-2007 05:45 PM
Pit Bull Stand? rdromano Twins Technical Talk 5 05-26-2007 02:05 AM
PIT BULL STAND 2002SPEEDTRIPLE Speed Triple Forum 3 01-18-2007 08:52 AM
Pit Bull stand KarmaPunk1 Speed Triple Forum 2 10-17-2006 08:08 PM
