Motorcycle.com Classifieds!SportbikeTrackGearSpringfield ArmoryShopTriumph.comAdvanstarMotorcycleShowsMotorcycle.comRacerPartsWholesaleTrident-Exhausts.com
SportbikeTrackGear
Old 02-15-2006   #1 (permalink)
HiVel's Avatar
My new bike wont start! Was running fine and had set up for about a week. Took it around the block (cold weather) and put it on the OPTIMATE charger and next day (yesterday) it would not fire. Blew out the right headlight somewere in the process. Maybe before the non-start issue but I replaced that. I have checked all my fuses and looked at the on/off kill switch etc. ---- Smell gas. Is it totally flooded and plugs fouled -overnight? What is happening. Anybody got any suggestions? I hate to go to the dealer as they dont seem to know much and it is a real PIA to load and go. Come on baby fire !!!! HELP
Anything worth doing is worth doing to excess!
2007 Tiger "Old Blue"
HiVel is offline   Reply With Quote
Old 02-15-2006   #2 (permalink)
So what's up Hivel? is it turning over fine, just not firing? Only reason I ask is because I've been having an issue with mine not wanting to start, but I think it may have something to do with the clutch switch. Mine won't do anything, but if I jiggle that safety switch for the clutch, it usually ends up working. Hoping to get mine to the dealer soon, so they can check it out, and replace whatever is faulty. I don't know what it could be with yours, if it's turning over strong and fine. I guess you could check your plugs, and make sure everything's alright there. Doesn't make any sense though, especially about the headlight thing and all. That sounds like something electrical, but then if you're smelling gas strongly, sounds like a fuel problem. I don't know man, but good luck!
[ This message was edited by: cheapbastard on 2006-02-15 09:17 ]
cheapbastard is offline   Reply With Quote
Old 02-15-2006   #3 (permalink)
HiVel's Avatar
Yes CB , my bike is turning over strong and all circuts appear to be working . I did not think it was possible to flood a CDI powered ignition that easily, usually they will fire most any rich mixture but maybe that is the deal?
Old 02-15-2006   #4 (permalink)
Mad
Two easy things I can think of is the kickstand switch and vacuum in the gastank. Make sure the connector to the switch is connected to the switch. You can also disconnect the switch and use a small jumper wire to defeat it just to see if the bike will start.
Just open the gastank opening to check for vacuum.
You probably already know this but never give the bike any throttle while trying to start.
Mad`
Mad is offline   Reply With Quote
Old 02-15-2006   #5 (permalink)
Favorite Bike: 2002 Speed Triple
Captain Obvious says:
"If the bike is in first with the kickstand down, it will crank without turning over."
:-D
blinker is offline   Reply With Quote
Old 02-15-2006   #6 (permalink)
Daahhhh... My 03 doesn't crank at all with the kickstand down and in first. It especially doesn't crank when I don't have the clutch pulled in. If your does, something is very odd. Heck, most of the time I use the kickstand to cut the motor when parking.
I know, I know, "bad Robert, always use the key to turn the bike off."
Old 02-15-2006   #7 (permalink)
ummm, correct me if I'm wrong guys, but what does the kickstand switch have to do with it? Hivel replied back to me and said the bike is turning over fine, just not firing. The bike wouldn't even turn over with the kickstand down and in gear, right? I thought it done nothing, just like the clutch switch. Mad might have something on the gas vacuum though. Might want to give that a check!
Old 02-15-2006   #8 (permalink)
Mad
Hey Cheap, you might be right about the kickstand switch. I haven't actually tried it but that ***** switch drove me crazy on my Busa.
Everytime I hit a bump in the road the engine would skip a beat and then start running fine again. No big deal but if I was under boost the turbo would load up with raw fuel and then when the ignition came back on it would backfire vioently and shoot a one foot flame out the side of the bike. It took me a month to find the problem.
The darn kickstand switch is kinda burned into my brain.
Mad`
Old 02-15-2006   #9 (permalink)
My 02 will crank but not turn over if the kickstand is down and the tranny is in first. If later models won't even crank in the same situation, then yes the kickstand switch isn't the problem.
Old 02-15-2006   #10 (permalink)
How will it crank without turning over?
NH Togas-Will they wake the dead? (or almost dead) johnnyb84 Twins Technical Talk 32 01-15-2008 01:37 AM
Water or Water Wetter??? kiel Speed Triple Forum 1 05-31-2007 10:39 AM
Dead in the water JTKMX Twins Technical Talk 7 12-05-2006 09:55 PM
T-100 Dead in the Water Motoboard Twins Talk 25 06-16-2006 06:32 AM
New Norton dead in the water???? stevecro Sprint Forum 0 06-10-2006 03:22 AM
