BikeBandit
Old 04-29-2004   #1 (permalink)
dentz
1999 speed triple . keeps cutting out .turn ignition on and rev counter sits on 3000, temp gage half heat ,press ign switch or any other major source of power and rev counter hits 0 and bounces, temp gage hits the roof but no starter . absolutely fine from cold runs for 30 mins then same fault . first started on outside lane m25 doing 90 scary stuff managed to ride home but now shes dead have checked loom no joy . any ideas.
Old 07-28-2004   #2 (permalink)
my 99' was down for a few months due to a short. It started slowly cutting out then one day...nuthin'. it turned out to be a bad ground.
good luck!
e.
Old 07-28-2004   #3 (permalink)
my friend's '99 s3 had the exact same problem. it turned out to be a bad connection in the 'ground distribution' connector. take off the seat and tank and look for a white connector with nothing but black wires going into it. his was obvious because one of the terminal locations had turned black from the heat. i just dumped the connector and soldered all the wires together and presto the bike is as good as new.
Old 07-28-2004   #4 (permalink)
Chainsaw,
May a good idea to add this to the troubleshooting area on this forum...It sure sounds like something I'd like to know about if I were in this situation .
I would add this myself, but I don't know enough about it ...Thanks, Jim
Quackster is offline   Reply With Quote
Old 07-30-2004   #5 (permalink)
Favorite Bike: T509, 1997
Other Motorcycle: MV Agusta F1000R
Extra Motorcycle: Yamaha GTS1000A
When I brought the bike in after I bought it, the dealer gave me a new connector like the one you guys are describing and said "oh yeah, buy this thing" Did not complain, less than $10. The connector is bad, they have a fix, it just ain't a recall.
Triple Trippin'
linsler is offline   Reply With Quote
its a mystery to me! doodledog Biker Hang-Out 5 07-10-2007 05:03 PM
Okay whats the mystery electrical connector on the T100? grayghost Twins Technical Talk 7 04-10-2007 07:33 AM
Mystery Bike EnglishBaz Classic, Vintage & Veteran 4 10-02-2006 06:33 PM
Mystery Hose spinner81 Twins Talk 7 05-31-2006 07:05 AM
Electrical Mystery, Anyone Hazard a Guess ? CYNCRZR Modifications & Workshop Talk 10 01-19-2006 06:59 PM
