Sppedometer error with gearing change? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-07-2006, 01:01 PM   #1 (permalink)
Favourite Bike: 2003 Speed Triple
DanPtWash's Avatar
Other Motorcycle: 2011 T-Storm
I am considering changing the gearing on my 03 S3.
(dropping down a tooth in front)
I found much discussion on how the change will effect quickness, top end, gas mileage, etc.. but I didn't see anything about speedometer error.
Does anyone have information regarding this? Or know where the speed is taken from? I'm guessing somewhere in the transmission.
Any help would be appreciated.
DanPtWash is offline   Reply With Quote
Old 02-07-2006, 01:11 PM   #2 (permalink)
It's taken from the front wheel, thus will not affect your speedo. :upthumb:
beers2u is offline   Reply With Quote
Old 02-07-2006, 01:28 PM   #3 (permalink)
DanPtWash's Avatar
Thanks Beers.
But I don't think you're correct here.
There are no cables on my bike going to the front wheel, just brake lines.
It has an electronic speedo which leads me to believe that it gets it's data from the primary gear.
Old 02-07-2006, 02:39 PM   #4 (permalink)
Look on the left hand side (as your sitting on the bike) of the axle. There is a cable that runs from the sensor unit up the fork leg, at least there is on my '04 which is mechanically the same.
Here's a pic where you can see both the brake line and the speedo cable...and it's a cool pic too!
Edit: I just checked the shop manual and the '03's are indeed the same.
[ This message was edited by: beers2u on 2006-02-07 13:16 ]
Old 02-07-2006, 04:03 PM   #5 (permalink)
Favourite Bike: 2003 Triumph Speed Triple
Yep, digital speedo on the front wheel. You can do whatever you want to gearing on the 02-04 without speedo issues.
Old 02-07-2006, 05:34 PM   #6 (permalink)
nice pic beers! :-D
6485 is offline   Reply With Quote
Old 02-07-2006, 11:22 PM   #7 (permalink)
Favourite Bike: 2007 White Tiger
redsled's Avatar
That picture looks like me on any given day :-D :-D I think my original front tire has lasted so long because it rarely touches the tarmac!
Chris Pope
Locust Grove, GA
2007 White Tiger (yeah, it's the fast one)
redsled is offline   Reply With Quote
Old 02-13-2006, 01:05 PM   #8 (permalink)
DanPtWash's Avatar
Beers,
Please except my apology for ever doubting you.
As you are well aware, you are completely correct.
Thanks again.
Old 02-13-2006, 01:52 PM   #9 (permalink)
No problem Dan!
from speedo error to speeding error! triumphtimes Daytona Deliberations 11 10-09-2007 11:43 AM
Looking to change gearing? Front or rear? fernman Speed Triple Forum 13 09-27-2006 08:16 PM
gearing and tyre change Qual Speed Triple Forum 6 03-14-2006 11:21 PM
Change S3 gearing; any recommendations? carbster09 Speed Triple Forum 8 01-06-2005 12:39 AM
Front sprocket gearing change Netmaker Trophy 5 05-29-2004 08:21 AM
