Gearing........probably not the last time. - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismSportbikeTrackGearMotorcycle.com Classifieds!Honda Powersports
Old 02-04-2006, 12:47 PM   #1 (permalink)
How many of us have dropped a tooth in front sprocket? I have on my '03 S3, and found acceleration has increased without sacrificing a whole lotta top end. (as noted in other threads regarding this). Has anyone found a good front AND rear sprocket combo? Or is dropping a tooth in the front, pretty much the way to go?
GrendelPrime is offline   Reply With Quote
Old 02-04-2006, 01:17 PM   #2 (permalink)
i've always done the rear sprocket.
zooplancton is offline   Reply With Quote
Old 02-04-2006, 01:42 PM   #3 (permalink)
Favourite Bike: Speed3 -09
Martin_R's Avatar
Same here. Easier to change a rear and the chain won't end up doing sharper bends than with stock.
I have tried 43 and 44 rears on my 05 and they both fit the stock chain just fine. I think dropping a tooth on the front or going 3+teeth bigger on the back might be too much for a 1050. Too revvy for my taste at least.
[ This message was edited by: Martin_R on 2006-02-04 11:43 ]
Martin_R is online now   Reply With Quote
Old 02-04-2006, 02:26 PM   #4 (permalink)
I love the stock gearing. Not saying you guys are wrong for wanting to gear yours, it's just the stock gearing fits my riding style perfect! If I don't gear this bike, it will be the 1st bike I've ever owned that I haven't geared! :-D But, I usually end up going down 1 in the front. It's not that much harder to change the front imo.
6485 is offline   Reply With Quote
Old 02-04-2006, 04:29 PM   #5 (permalink)
Favourite Bike: '01 Speed Triple
I went to a 45T on the rear, and can swap between the 18 and 19T countershaft sprockets with a chain adjust. I like the 19/45 setup the best.
Speed3 is offline   Reply With Quote
Old 02-04-2006, 04:35 PM   #6 (permalink)
Favourite Bike: 2003 Triumph Speed Triple
Lol, I've said this too many times in the past, but I'm +3 in the rear and -1 in the front for a 17/45 combo and mine accelerates like a bat outta hell. I'm probably going to switch back to the stock front sprocket though since +3 in the back does plenty on its own, and 1st gear wheelies are just plain scary with the 17/45. The front wheel wants to shoot up just way too fast, and being a wheelie nut, I'd like something a bit smoother and predictable.
Otherwise, the 17/45 combo just turns the bike into a real beastie and puts the power at every rpm after 4k rpm. You might just try it for sheets'n'giggles sometime.
Old 02-04-2006, 04:54 PM   #7 (permalink)
Martin_R's Avatar
Isn't 19/45 pretty much the same as the stock 18/42? Or does the stock 01 have some other factory settings?
Old 02-04-2006, 05:34 PM   #8 (permalink)
My stock gearing is 18/43, and the 19/45 is a bit lower than that. Everyone was saying how good 18/45 is, so I tried it, but found the 19 better for the high speed riding I do.
Old 02-04-2006, 06:17 PM   #9 (permalink)
How is 19/45 better for high speed riding? Adding one tooth up front is like dropping 3 teeth in the back isn't it? Wouldn't that make the rpm's lower at higher speeds, meaning less power when you need it to push you over 100mph?
It took me forever to get up to 140 in a full tuck with the stock gearing. Now I get up to 135 FAST with the 17/45!
[ This message was edited by: kuhlka on 2006-02-04 16:17 ]
Old 02-04-2006, 06:57 PM   #10 (permalink)
I like the 19 because when I do 400 mile days or 1000 mile weekends, it's nice to have the taller gearing. Like I said, If I want to have quicker acceleration for blasting around town, I can throw on the 18T.
Triumph sucks big time. Will buy Honda next time. drainbamage Speed Triple Forum 28 02-25-2009 11:06 PM
Winter-time is the Mod-ing Time Raindogs Twins Technical Talk 12 01-29-2008 02:08 PM
long time lurker,1st time poster gaptooth grin Twins Talk 9 07-29-2007 10:14 AM
Gearing Nickwiz Daytona Deliberations 8 09-22-2005 08:58 AM
