Spark Plugs on the '05 S3 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-03-2006, 03:26 PM   #1 (permalink)
The manual states that the plugs installed in my bike are NGK-CR9EK. This is a multi-ground plug. I have read that, in some cases, a multi-ground plug may perform worse than a traditional plug. My question is if I switched to a Denso Iridium plug when I do my Spring Tune-Up would it effect performance or cause harm to the engine?
MD05S3 is offline   Reply With Quote
Old 02-03-2006, 04:38 PM   #2 (permalink)
If you dont like the dual electrode just go to a CR9E. I've used both in my YZF and cant tell the difference. The wallet can though. THose EK's are pricey.
Unless you want the Iridium ones cause you think it will go faster.
Chris
Custom undertail exhaust, ceramic coated black, black powder coated headlight buckets and radiator shrouds, Cateye mirrors, Pazzo shorty levers.
TripleTrouble is offline   Reply With Quote
Old 02-03-2006, 04:56 PM   #3 (permalink)
Nah, just a question I had swimming around in my head.
New Ignition Coil, Spark Plug Wires and Iridium Spark Plugs...better performance? brownbomber Twins Talk 15 10-27-2009 04:25 PM
Spark plugs? awegs955i Daytona Deliberations 11 02-07-2009 02:25 AM
spark plugs schmark plugs DaleE Hinckley Classic Triples 6 10-25-2005 11:54 AM
Spark Plugs msparks Sprint Forum 6 01-21-2005 05:02 PM
Spark Plugs? Sprint Forum 9 11-19-2004 04:16 AM
