Favorite Bike: tied between my '02 S3 and my '06 R3
Other Motorcycle: Bonneville
My S3's friggin check engine light keeps coming on and no one can tell me why? has anyone else had this problem and if so were you able to fix it and how?
That which doesn't Kill you will only require brief Hospitalization!!!!
Well unfortunately it's hard to say, it could be anything from a bad temp sensor to a problem with the FI. You need to run a diagnostic check to see what the on-board computer's error code is. From there you can get to the root of the problem. Your dealer should have the appropriate hardware/software to retrieve the error code from the OBC. Good luck and happy riding.
