ShopTriumph.comRacerPartsWholesaleMotorcycle.comBikeBanditTrident-Exhausts.comMotorcycle.com Classifieds!Springfield ArmorySportbikeTrackGear
Old 01-28-2006   #1 (permalink)
Now we all (I'm assuming) get our pretty, new, better sounding exhaust and just slap it on then forget it. But when should you repack (if able)? How many miles should you allow to go through an aftermarket pipe before you freshen it up. Also, how do you go about removing the rivets? Anbody have experience with this? I'm sure just getting a new can/s would be a quick (and expensive) fix, but what if you like what you got? Anyone want to take this one.................
GrendelPrime is offline   Reply With Quote
Old 01-28-2006   #2 (permalink)
you remove the rivets with a drill bit that is not much bigger (if at all) than the holes that are already there. You dont want to make the holes very much bigger than they are. Then you need a cheap pop rivet gun to put them back. I just drill the heads off then tap the rivet through with a punch so I dont actually drill the hole any bigger. Ive always wanted to see if I could get some small nuts tacked on to the inside of the can so I could replace the rivets with small allen head bolts to make the next repack easier. I would also like to experiment with different packing material to try to achieve different sounds.
Hotmailjerk is offline   Reply With Quote
Old 01-28-2006   #3 (permalink)
Thanx H.M.J.! Would you happen to know where I could find a cheap riveter? Maybe for this specific task?
Old 01-29-2006   #4 (permalink)
Home Despot
Lowes
Sears
"Nothing is ever what it seems but everything is exactly what it is." - B. Banzai
Rubbus is offline   Reply With Quote
Old 01-29-2006   #5 (permalink)
Favorite Bike: '01 Speed Triple
I've repacked my TBR can twice, and it's very easy. Two Brothers sell a repack kit for 19 bucks, that comes with packing material, rivets and a drill bit the correct size.
Speed3 is offline   Reply With Quote
Old 01-29-2006   #6 (permalink)
Same here, the TBR was a snap. Highly recommended!
A decient rivet tool is about ten bucks.
AndrewTriumph is offline   Reply With Quote
Old 01-29-2006   #7 (permalink)
Favorite Bike: '01 S3
2bugeyez's Avatar
Other Motorcycle: lookin for my '96 T-bird
Anybody repacked a TOR can?
Speed thrills!
2bugeyez is offline   Reply With Quote
D & D Repack Pic... Hozer Club Cafe 12 06-13-2006 09:35 AM
D&D repack, revisited WANG Club Cafe 11 02-09-2006 12:20 PM
repack triumph carbon low pipe ryan Modifications & Workshop Talk 2 08-08-2005 01:11 PM
Repack a Micron or slip on exhaust? menelfloss Modifications & Workshop Talk 15 05-04-2005 02:13 AM
Repack a Micron or slip on exhaust? menelfloss T3 Sport / Touring Forum 7 04-19-2005 12:49 AM
