difference between cali, and other triples? - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com
Old 01-19-2006, 05:27 PM   #1 (permalink)
is there any difference in the power ratings of Speed Triples sold in california, and other areas of the country? For instance, i know that cars sold in califonia are equipped with special emissions equipment thatn reduce the power output, while the same vehicles sold elsewhere are not equipped. This is due to California's emissions laws. Any ideas triumph fans?
PONCH85RS is offline   Reply With Quote
Old 01-19-2006, 09:38 PM   #2 (permalink)
Favourite Bike: 2002 Speed Triple
Other Motorcycle: ATK250LQ
From looking at the service manual the only difference I noticed for California models was the addition of a carbon canister and related plumbing to capture fuel vapors off the tank. This shouldn't affect the power rating at all.
xpwarrior is offline   Reply With Quote
Old 01-19-2006, 11:25 PM   #3 (permalink)
where is the canister located, and can it be deleted?
Old 01-20-2006, 06:58 PM   #4 (permalink)
The canister is supposed to be located behind the throttle bodies and the return valve is listed as adjacent to the frame left hand side. The rest is just hoses running to the idle bypass lines, the canister, the return valve and the fuel tank. The return valve is controlled by the computer and a trouble code will happen if you disconnect it. I'm not sure how you can get past this. :???:
Old 01-20-2006, 07:27 PM   #5 (permalink)
i've talked to the guys at munroe and you can remove the set up. as for knowing *what* they do in the process, i have no idea...
-b
zooplancton is offline   Reply With Quote
Southern Cali Rally dano Rides & Events 27 05-21-2008 01:37 AM
cali smog unitedrocker Twins Technical Talk 3 05-08-2007 02:46 PM
So, for you Cali guys... Psychlopath Twins Talk 8 03-13-2007 02:13 PM
What is the difference between the triples? Silly_me Hinckley Classic Triples 11 06-07-2006 06:02 PM
No. Cali. Bikers cold??? Thunder_Forever Twins Talk 16 02-13-2006 05:48 AM
