Bleed niples - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.comMotorcycle.com Classifieds!
Old 01-01-2013, 05:54 PM   #1 (permalink)
Main Motorcycle: 2004 Triumph Speed Triple
1peter's Avatar
Bleed niples
Just wondering if anyone has used "speed bleed niples". Do they work ? http://www.ebay.com.au/itm/Speed-ble...item5d27f8db41
1peter is offline   Reply With Quote
Old 01-01-2013, 06:06 PM   #2 (permalink)
Main Motorcycle: '01 Speed Triple
I have them on my bike, and it makes brake bleeding easy. I use a Mityvac as well.
Speed3 is offline   Reply With Quote
Old 01-01-2013, 06:08 PM   #3 (permalink)
Main Motorcycle: 2007 Speed Triple
Yes, I use them and they do work extremely well. It makes an already simple job that much easier. You just open the nipple a bit, pump the brake l, make sure you keep fluid in the reservoir and when bubbles are out and have good clean fluid, you are done. Easy peasy. Oh and of course you need a hose from the nipple to an appropriate receptacle.
Night Train is offline   Reply With Quote
Old 01-01-2013, 06:43 PM   #4 (permalink)
Main Motorcycle: 06 Speed Triple
Delan's Avatar
Other Motorcycle: Vespa PX
Extra Motorcycle: Aprilia RS250
fitted a set a week ago. don't know how I managed without them to be honest.
Cheers, Delan
Delan is offline   Reply With Quote
Old 01-02-2013, 03:23 AM   #5 (permalink)
1peter's Avatar
Thanks a bunch, i will order them.
Old 01-02-2013, 04:00 AM   #6 (permalink)
1peter's Avatar
I have since read that you need some sort of thread tape because eventually the old stuff deteriates over time ?
Old 01-02-2013, 04:28 AM   #7 (permalink)
hac
Main Motorcycle: 09 speed triple
hac's Avatar
This sort of thing works well too
http://www.ebay.co.uk/itm/DRAPER-BRA...item1e652c41ad
hac is online now   Reply With Quote
Old 01-02-2013, 05:11 AM   #8 (permalink)
Main Motorcycle: 05 Speed Triple
Ferris's Avatar
How often do you plan on bleeding your brakes? I purchased the sealant http://www.speedbleeder.zoovy.com/pr...T/Sealant.html that goes with the bleeders, though I still haven't had to use it.
You could just buy the lot there?
Ferris is offline   Reply With Quote
Old 01-02-2013, 05:51 AM   #9 (permalink)
1peter's Avatar
Originally Posted by hac View Post
I've got a similar thing to that but if the hose pops off you are sucking air, not with the speed bleeder nipples.
Old 01-03-2013, 03:51 AM   #10 (permalink)
Main Motorcycle: '08 1050 Orange Triple
Other Motorcycle: Suzuki gsxr-1000 racer
plus one!
gsx97 is offline   Reply With Quote
Brake bleed uh oh Zehman@hotmail.com Twins Technical Talk 35 09-27-2012 12:40 AM
clutch bleed lexus31rus Hinckley Classic Triples 8 04-09-2012 03:43 AM
ABS Brake Bleed...HELP! shadygrady Tiger 800 - 800XC Mods & Workshop 17 04-06-2012 10:44 AM
Rear brake bleed... Mikie M. Tiger Workshop (archive) 2 02-17-2011 05:29 AM
How do you bleed your brakes? R100Pilot Speed Triple Forum 8 06-28-2006 04:32 PM
