Bleed niples - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 01-03-2013, 04:01 AM   #11 (permalink)
hac
Main Motorcycle: 09 speed triple
hac's Avatar
Originally Posted by 1peter View Post
I've got a similar thing to that but if the hose pops off you are sucking air, not with the speed bleeder nipples.
Try a zip tie on the hose,the biggest problem I had was that I undone the nipple 1/4 of a turn which was too much.You can then suck air in through the nipple threads,
hac is online now   Reply With Quote
Old 01-03-2013, 06:45 AM   #12 (permalink)
Main Motorcycle: '01 Speed Triple
If you smear grease on the nipple before you loosen it, it will prevent air from getting sucked into the system.
Speed3 is offline   Reply With Quote
Old 01-04-2013, 01:00 AM   #13 (permalink)
Main Motorcycle: 2004 Triumph Speed Triple
1peter's Avatar
Good idea.
1peter is offline   Reply With Quote
Brake bleed uh oh Zehman@hotmail.com Twins Technical Talk 35 09-27-2012 12:40 AM
clutch bleed lexus31rus Hinckley Classic Triples 8 04-09-2012 03:43 AM
ABS Brake Bleed...HELP! shadygrady Tiger 800 - 800XC Mods & Workshop 17 04-06-2012 10:44 AM
Rear brake bleed... Mikie M. Tiger Workshop (archive) 2 02-17-2011 05:29 AM
How do you bleed your brakes? R100Pilot Speed Triple Forum 8 06-28-2006 04:32 PM
