AdvanstarMotorcycleShowsShopTriumph.comSpringfield ArmoryMotorcycle.com Classifieds!Motorcycle.comBikeBanditTrident-Exhausts.comSportbikeTrackGearRacerPartsWholesale
Old 01-17-2006   #1 (permalink)
Take one slightly rashed clutch cover and 3 hours later = BLING
Before>
After>
And fitted>
It even looks better in the flesh!
nissn1 is offline   Reply With Quote
Old 01-17-2006   #2 (permalink)
Favorite Bike: Triumph Speed Triple
scouselee's Avatar
Other Motorcycle: Harley hardtail chop
Extra Motorcycle: Yamaha Dragstar
that looks sweet, well done that man :upthumb:
One Day,...Maybe
scouselee is offline   Reply With Quote
Old 01-17-2006   #3 (permalink)
Thanks scoucelee, its a bit of old school but really contrasts well with the all black engine. I left the three holes original black as i had intended to do the whole cover and chrome the bolts but this looks better! I am not a fan of all black engines, probably because i have been used to nortons , early triumphs and harleys. Lots of bling :-D
Old 01-18-2006   #4 (permalink)
And flyscreen added today
Old 01-18-2006   #5 (permalink)
ES3
Don't forget to change the pic in your Signature! :-D
No more Triumph
ES3 is offline   Reply With Quote
Old 01-18-2006   #6 (permalink)
Favorite Bike: 2007 White Tiger
redsled's Avatar
Did you use anything special, or just take steel wool and then poish with Semi-Chrome? I'm going to do the same thing. That looks great.
Chris Pope
Locust Grove, GA
2007 White Tiger (yeah, it's the fast one)
redsled is offline   Reply With Quote
Old 01-18-2006   #7 (permalink)
Looks great did you polish it yourself . Also where did you get the front brake resevoir?
kevf is offline   Reply With Quote
Old 01-18-2006   #8 (permalink)
Favorite Bike: Speed Triple
Catenaccio's Avatar
Other Motorcycle: Speed Four
Extra Motorcycle: CBR1100XX
Nice look! Did you clear coat the cover after polishing?
Catenaccio is offline   Reply With Quote
Old 01-18-2006   #9 (permalink)
Yes i polished it myself , have saw fingers to prove it! First i started with coarse wet and dry 180, then 240,400,600 and finished with fine 800 grade! Use 2 sheets of 180 coarse as the black powdercoat takes a little work to get completely off. The rest is pretty easy. When finished sanding using wet and drypaper (with water) cover looks a bit like brushed aluminium, but then when i polished with autosol (alloy polish) it becomes instantly shiny! Spent around half hour polishing. Well worth it ! You will love the results1 No lacquer applied as its very easy just to go over with a little alloy polish every now and again. You will have noticed that the 3 bolt holes remain black and untouched! Brake reservoir is Rizoma! cheers, steve
Old 01-19-2006   #10 (permalink)
redsled's Avatar
Well Steve, since you did such a fine job and have the method down, I'll send you mine to do. It's winter here and I'm not riding much, so I won't miss the cover for a while. Thanks a lot!!
Chris Pope
Locust Grove, GA
Latest mod-Keihen CR's SHRuuM Club Cafe 7 10-02-2007 02:53 PM
Latest Mod Loxpump Twins Talk 2 09-14-2006 09:35 PM
My latest mod... UJ/US d2mini Twins Talk 3 02-16-2006 08:34 PM
My latest mod fuzzdevil Twins Talk 27 01-18-2006 08:12 PM
latest mod rictus01 Speed Triple Forum 3 10-14-2005 09:34 PM
