Fuel pump O-ring seal positioning? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 3 (permalink) Old 12-11-2012, 01:45 AM Thread Starter
Main Motorcycle: 08 speedy black
stuh's Avatar
Hi there,
My 08 speedie is leaking fuel , by the looks its from around the fuel pump.
So, I took it apart , the o-ring "looks" ok , but i have ordered another one just in case.
My question is, i noticed the O-ring has a groove in it, is it meant to be mounted on the rim of the tank itself (in the groove)?
or just sit on the underside of the tank with the base of the fuel pump pressed against it ?
thanks for your help.
(PS, the current one was NOT mounted on the rim.
Around OZ on my speedie.
http://stu-h.tumblr.com/archive
stuh is online now
post #2 of 3 (permalink) Old 12-11-2012, 03:21 AM
Main Motorcycle: 2007 Speed Triple
Lord Flashheart's Avatar
Other Motorcycle: 2006 Speed Triple
I took a look at my manual, it says (copied verbatim):
1 If removed, position a new '0'-ring seal in the tank aperture and ensure that it is correctly seated
2 Taking care to ensure the '0'-ring is not damaged or dislodged, manoeuvre the fuel pump assembly into the tank aperture with the 'FRONT' arrow is facing towards the front of the fuel tank.
3 Tighten the mounting plate fixings to 5 Nm.
I actually did this when I first got my bike 4 years ago; I got a free set of black bodywork, so I swapped the pump and fuel cap from the original white tank to the new black one. Damned if I can remember much about it, though. Sorry.
Lord Flashheart is offline
post #3 of 3 (permalink) Old 12-11-2012, 04:51 AM Thread Starter
stuh's Avatar
Hi there,
thanks, I've managed to get a workshop manual , and yeah the word "aperture " makes me think it is meant to go on the rim of the opening itself.
the existing one wasnt like that , it was resting on the outer edge basically "clamped" inplace by the pump assembly...
stuh is online now
Fuel pump side and extra fuel TX1911fan Air Cooled Twins Technical Talk 8 09-11-2014 05:42 AM
Stalling/starting issue - Fuel Sender/Fuel Pump? Mordgier Sprint Forum 11 02-06-2012 07:15 PM
URGENT PLEASE: 08-09 Fuel Tank on a 07??? Fuel Pump Assembly Problems/Compatibility Sweatypants Speed Triple Forum 4 10-02-2010 01:09 AM
Thruxton Accelerator Pump O-Ring ammoguy100 Air Cooled Twins Technical Talk 5 06-10-2010 07:10 PM
Question about the fuel connectors attached to the fuel pump mounting plate zapata Speed Triple Forum 2 11-16-2008 11:11 PM
