Instrument Push Buttons Replacement? - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
SportbikeTrackGearMotorcycle.com
Old 12-10-2012, 08:43 AM   #1 (permalink)
Main Motorcycle: 2006 Speed Triple 1050
Good morning all - New Speedy owner here with a question I wasnt expecting to have to ask. My buddy and I (fellow s3 owner) were riding shortly after I got mine and he was telling me how to reset my trip function. Nothing I tried worked. The trip button feels squishy, not clicking under it. The 1st button is crisp, second is simi there, and the third, not at all. We pulled off my gauges, pulled apart the case and found some corrosion on the switches. Looks almost like a little water got in there and sat. With the board exposed and the switch posts sticking up in the air, you can see clearly that there is no movement on that particular switch. Question being - should I source a new board, source a new switch and have someone put it in, or just ride with out that function? The fact that the switch broken is the switch needed to reset, I wont be able to reset mpg, speeds, trip etc. I have been really surprised at how serviceable everything has been so far which is great for me as I like to do my own work.
twisted125 is offline   Reply With Quote
Old 12-10-2012, 11:39 AM   #2 (permalink)
Legend
DEcosse's Avatar
(Please add your model year to your 'main motorcycle' description)
Here you go - I updated it with source info
http://www.triumphrat.net/speed-trip...dont-work.html
Old 12-10-2012, 09:08 PM   #3 (permalink)
awesome - thanks for the links DEcosse! I was hoping you would chime in, heard you had some good knowledge between your ears.
Light bulb replacement in instrument cluster oddsteven Twins Technical Talk 2 10-11-2011 11:23 PM
Instrument lights stencil/fascia (not sure on the term) replacement thunderpants Hinckley Classic Triples 7 06-04-2009 11:57 AM
98 Daytona instrument bulb replacement with LEDS alexofc69 Daytona Deliberations 0 12-17-2008 01:59 PM
Remote Instrument Buttons jabingb Street Triple Forum 0 12-31-2007 12:01 AM
Instrument cluster replacement xSpeed3x Speed Triple Forum 7 11-28-2005 08:03 PM
