bike starts and shuts off if i dont give throttle - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-09-2012, 03:19 PM   #21 (permalink)
Main Motorcycle: 2003 955i speed triple
And I have taken the stator cover off, and taken stator out, and it wasn't burnt or anything, looked normal.
Might borrow a new battery from work and see if it has same readings.
Sent from my HTC One X using Motorcycle.com Free App
Brian.DeRemer is offline   Reply With Quote
Old 12-09-2012, 04:42 PM   #22 (permalink)
Legend
DEcosse's Avatar
Once it passes both isolation and voltage tests it is not necessary to remove it - already proven good.
Most likely your R/R is bad.
Don't know how I missed this before
Originally Posted by Brian.DeReimer
tps closed- 11.40
tps wot- 82.4
That is WAAYYY off - you need to zero that.
Should be '0' and '~ 70' respectively so you have an offset of about 11.
Nothing to do with the Generator issue, but would explain why bike would surely run horribly (surprised it runs at all!!!)
Old 12-09-2012, 05:44 PM   #23 (permalink)
Sorry again. I removed it a while back when the case was cracked after the guy before me layed it down.
Awesome, I thought the tps numbers might be off, good thing I posted it all. Thanks for the heads up
Old 12-09-2012, 05:56 PM   #24 (permalink)
Tried to search a little, is it like adjusting on a car, just loosen, and turn it till its at zero, then tighten?
I assume it's under the air box as well?
Battery drops rather quickly after being charged, have the new one charging right now, then maybe I'll get more accurate readings.
Old 12-09-2012, 06:05 PM   #25 (permalink)
Legend
DEcosse's Avatar
It's software zero with TuneEcu
The TPS voltage at throttle closed should be ~ 0.6V +/- 0.05V - you can read that directly off TuneEcu diagnostics in left margin; it is unlikely that you will have to physically change the tps potentiometer, just apply the auto-zero function; then after you zero should read 0% on the graphic display in diagnostics and ~70% wot - the voltage itself will be un-changed.
When you go to map edit screen you will now see on tps axis it will now go from zero to 100 on the axis itself
Old 12-09-2012, 06:15 PM   #26 (permalink)
Legend
DEcosse's Avatar
Re battery volts dropping - pull fuse 9 to keep headlights off while using TuneEcu
Old 12-09-2012, 06:30 PM   #27 (permalink)
Ok, I don't have the data cable to hook to my computer, guess I'll put it on my Christmas list. Haha
Old 12-09-2012, 08:25 PM   #28 (permalink)
Legend
DEcosse's Avatar
Confused - where did you get the numbers you reported in post #1
Or did you just measure actual tos voltage and calculate those as % of 5V? That's not how it works - the ECM does the conversion and offset
Old 12-09-2012, 09:38 PM   #29 (permalink)
I have a ObdII scanner that reads the info I shared. Also like oxygen sensor data, temp, and so forth.
Old 12-09-2012, 10:02 PM   #30 (permalink)
Legend
DEcosse's Avatar
Ok so it appears to have done a calc on % of voltage:
0.6/5.0= 12%
4.0/5.0= 80%
But those numbers are totally meaningless
Bike shuts off going over bumps Garar Twins Technical Talk 3 09-08-2011 10:25 PM
It starts...it idles...i twist throttle and it dies. NYC888 Twins Technical Talk 7 07-15-2011 11:26 AM
They dont like my bike will_s Thunderbird Cruiser Chat 10 04-29-2011 01:02 AM
Engine starts choking with open throttle cocoselect Twins Technical Talk 7 07-12-2009 08:47 PM
dont you love other dedicated bike forums talikng about your bike bakwheeltango Sprint Forum 11 07-31-2007 08:03 AM
