bike starts and shuts off if i dont give throttle - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-08-2012, 05:13 PM   #11 (permalink)
Legend
DEcosse's Avatar
correct - and stator unplugged.
If it fails (stator short to ground) don't worry about starting - pull cover and see the evidence
Old 12-08-2012, 05:22 PM   #12 (permalink)
Main Motorcycle: 2003 955i speed triple
If I disconnect the fuel line on top, fuel should spit out when I prime? it does not. I think my fuel filter might be clogged? sound likely?
Brian.DeRemer is offline   Reply With Quote
Old 12-08-2012, 05:26 PM   #13 (permalink)
SUPER Line-X'd Moderator
Main Motorcycle: 2006 Speed Triple
DieselGeek's Avatar
Pretty sure those are " dry break" connectors .
They are designed to not leak when " open "
DieselGeek is online now   Reply With Quote
Old 12-08-2012, 06:40 PM   #14 (permalink)
Legend
DEcosse's Avatar
The OEM original was dry-break (valved) plastic; the recall replacements were aluminum and non-valved
If valved you do NOT want to run pump or you will possibly rupture or blow off the hose off the fuel filter
Old 12-08-2012, 06:54 PM   #15 (permalink)
I bought a new fuel filter from AutoZone. 3.99.
Gonna replace it since ii replaced my fuel pump anyways.
unplug stator connector(3 pin)
negative probe to ground.
positive on any pin.
test all 3 pins.
my multi meter does nothing.
get the same reading if I stick the probes into the sky.
what should it be saying?
Old 12-08-2012, 08:11 PM   #16 (permalink)
Legend
DEcosse's Avatar
That is good - what you want
Old 12-08-2012, 11:27 PM   #17 (permalink)
Haha, well that's good. At least I know now. That's again for your help. I'll let you know the outcome tomorrow morning.
Sent from my HTC One X using Motorcycle.com Free App
Old 12-09-2012, 01:10 PM   #18 (permalink)
At idle the reading was at ~20V and at 5k it was at ~70V. Those reading seem good.
I measured the volts when bike was running, and was only like mid 12s.
I measured the output from the voltage regulator, and it was about half a volt higher than the battery was reading. I assume this is why people cut the wires and run them to the battery.
In my mind, I know the stator is putting out, but the voltage is too low. So the voltage regulator is at fault?
Old 12-09-2012, 01:48 PM   #19 (permalink)
Legend
DEcosse's Avatar
You gave volts but it's not clear if you checked all three phases - please confirm - all three should be the same at any given rpm
Good chance stator is good especially since passes isolation test but confirm voltages
If stator is good then most likely your R/R is bad - do make sure you check out that first stator connector
Old 12-09-2012, 03:18 PM   #20 (permalink)
I checked all 3 phases
1-2
2-3
3-1
All had same readings at all rpms. Sorry I didn't mention that.
Bike shuts off going over bumps Garar Twins Technical Talk 3 09-08-2011 10:25 PM
It starts...it idles...i twist throttle and it dies. NYC888 Twins Technical Talk 7 07-15-2011 11:26 AM
They dont like my bike will_s Thunderbird Cruiser Chat 10 04-29-2011 01:02 AM
Engine starts choking with open throttle cocoselect Twins Technical Talk 7 07-12-2009 08:47 PM
dont you love other dedicated bike forums talikng about your bike bakwheeltango Sprint Forum 11 07-31-2007 08:03 AM
