Originally Posted by Kreuzwieser
I'm wondering if the guages off of an 11 Street Triple will work on a '10 S3.
I doubt it, as even the S3 gauges do not work across generations.
But if plastic is all that is broken on your original clocks, the outer shells of similar shaped 675 & Speed Triple gauges do interchange.
-> Cheapest route would be to buy any same shape gauges, that have OK exterior, but fried innards. Then you could switch the mint plastics to your own clocks.
Is your bike a proper 2010, or one of the US importer's fake ones? As in is your broken gauge cluster of this newer shape:
http://www.ebay.com/itm/TRIUMPH-DAYT...item3a7c55a0be
For the older shape outer fascias are also available from Triumph.
