Leo Vince Evo II Factory R - low mount carbon exhaust - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-04-2012, 06:14 AM   #1 (permalink)
Main Motorcycle: 2011 Speed Triple
Ben_'s Avatar
Just had my first ride after installing the new exhaust...
Eargasm!
So throaty and there seems to be a noticeable bump in the higher RPMs
Leo Vince reckon it is designed to run on the stock map but I suspect better results could be had by loading the arrow low mount map.
Any thoughts?
Ben
Ben_ is offline   Reply With Quote
Old 12-04-2012, 07:26 AM   #2 (permalink)
Main Motorcycle: 2012 Triumph Speed Triple
bradvanhorn's Avatar
Other Motorcycle: 2009 Kawasaki ZX-6R
Extra Motorcycle: 2012 Kawasaki Ninja 250
I just mounted that same exhaust last night. I've got all my lights disconnected for track duty so I didn't get to ride. Sadly we're going to have thunderstorms all day today so it may be another day or two before I can ride.
I'm curious to see what comments come up regarding the best tune to use. I'm thinking about going to the dyno shop for a custom tune but I wouldn't mind saving a couple hundred dollars if the Arrow lowboy tune already is a solid choice.
bradvanhorn is offline   Reply With Quote
Old 12-04-2012, 09:36 AM   #3 (permalink)
hac
Main Motorcycle: 09 speed triple
hac's Avatar
Why not just load the arrow low boy tune with tune ecu and see which one you prefer.A dyno is the only way to really tell which tune is best,louder exhausts can be deceptive.
hac is offline   Reply With Quote
Old 12-04-2012, 12:36 PM   #4 (permalink)
Main Motorcycle: 2002 H-D Road King
robinpeck's Avatar
Extra Motorcycle: 2011 Triumph Speed Triple
My wife has ordered me one for Christmas...(when it arrives, she'll wrap it and put it under the tree.) I've been running stock pipes for two years...I don't really care about the exhaust note...just want the weight loss and the weight lower. The bike sounds fine to me with stock mufflers. I really don't care what it sounds like to others...just so long as the cops ignore me.
By the way, can that LeoVince sticker be taken off the can without too much trouble?...and how much more of a hassle is it to change the rear tire?
robinpeck is offline   Reply With Quote
Old 12-04-2012, 12:51 PM   #5 (permalink)
I have just about the same feelings. I honestly like the stock look fairly well - I'm actually not very excited about the look of the LV low. But, I wanted to lower the weight/CoG so this is where I ended up...
Not sure about removal of the LV badge - I would like to remove it but don't want to mar the finish of the can in the process, so I'll probably leave it alone.
I haven't tried removing the rear wheel but I suspect the can will have to come off to do so. Shouldn't be hard - remove two springs and one bolt and the can will slide off.
Old 12-04-2012, 01:27 PM   #6 (permalink)
robinpeck's Avatar
Originally Posted by bradvanhorn View Post
Sadly we're going to have thunderstorms all day today so it may be another day or two before I can ride. .
another day or two? It snowed some yesterday....more predicted this week...and so it begins....I'll be going for a ride in about 4 months!!!
Its bike building (SR 500 street tracker) in my (heated) workshop until spring.
Old 12-04-2012, 01:37 PM   #7 (permalink)
Ouch . Yeah, sorry to rub that in. One benefit to living on the Gulf coast I suppose...
Old 12-04-2012, 04:54 PM   #8 (permalink)
Main Motorcycle: 2008 S3
Bennyman's Avatar
Other Motorcycle: SV650
Ohhhhh great, now I am on revzilla looking at new exhausts!!!!!!!
Bennyman is offline   Reply With Quote
Old 12-04-2012, 05:32 PM   #9 (permalink)
Main Motorcycle: 2012 Speed Triple
Tilt's Avatar
Actually with stock down pipe and CAT you may find (as I did) that the arrow twin high pipe is more appropriate. Else get it on a dyno with a custom map.
Tilt is offline   Reply With Quote
Old 12-04-2012, 09:11 PM   #10 (permalink)
Main Motorcycle: 2012 Speed Triple R
Other Motorcycle: Aprilia Scarabeo Scooter
Peeled mine right off. Didn't mar the finish. Didn't even use a heat gun.
Custom tune.
Scriber is offline   Reply With Quote
Leo Vince factory Exhaust Questions redmosquito1 Daytona675 Forum 3 11-28-2010 02:09 PM
My New Leo Vince Carbon Exhaust KuwlTriple Speed Triple Forum 15 05-10-2007 11:27 PM
