Is this a legit bar-end mirror setup? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-29-2012, 09:43 PM   #1 (permalink)
Main Motorcycle: 2011 Speed Triple 1050
Dr.Speed's Avatar
Smile Is this a legit bar-end mirror setup?
I wanted to get rid of the antlers off my diablo red 2011 Speed Triple, and decided on ordering crg arrow mirrors and universal mounts. Should these give me any trouble?
Mirrors: http://www.solomotoparts.com/CRG-Arr...ar-End-Mirror/
Adapter: http://www.solomotoparts.com/CRG-Bil...Mount-Adapter/
Thanks for the feedback!
Dr.Speed is offline   Reply With Quote
Old 11-29-2012, 11:05 PM   #2 (permalink)
SUPER Line-X'd Moderator
Main Motorcycle: 2006 Speed Triple
DieselGeek's Avatar
I do not know the measurement on the new model bars but as long as they are not fat bars that should work real slick for you
DieselGeek is online now   Reply With Quote
Old 11-29-2012, 11:11 PM   #3 (permalink)
Dr.Speed's Avatar
Awesome. I canceled the order of some R&G bar end sliders, because I don't think any bar end mirrors will work with them... I guess I'll just use the universal adapters for now.
Old 11-29-2012, 11:13 PM   #4 (permalink)
Main Motorcycle: '06 Speed Triple
Other Motorcycle: '96 Adventurer Cafe Racer
Extra Motorcycle: Not any more
I run CRGs on mine without adaptors, but I'm not sure if the bars are the same size on my '06.
Interesting mirror- looks good. I'm not trading my lane splitters though...they've proved handy a time or two when I squeezed a bit more than I maybe should have. I'm guessing that's not an issue in PA.
Don
'06 Speed Triple
and a bunch of other stuff
If everything seems under control, you're just not going fast enough - Mario Andretti
zelatore is online now   Reply With Quote
Old 11-29-2012, 11:15 PM   #5 (permalink)
Dr.Speed's Avatar
Yeah, no lane splitting for me unfortunately. I think the round mirrors kinda flow with the round headlights... and the CRG arrows kinda mimic the look of the new style headlights.
Old 11-30-2012, 05:34 AM   #6 (permalink)
Main Motorcycle: 2011 S3
They will not work on the '11 because the end of the bars are solid with a 6mm bolt hole. I bored out the end of my bars to accept those kind of mirrors that slide into the handlebar
Jerry Holland
Man, you were haulin ass the other day when I passed you.
cognosticator is online now   Reply With Quote
Old 11-30-2012, 07:08 AM   #7 (permalink)
Main Motorcycle: 2007 Speed Triple
I disagree cognosticator .There is an alloy 18mm threaded plug that hopefully comes out when you unscrew the allen bolt that holds the end caps on .You may need a heatgun to soften the threadlock that holds them in there .Once they are out the adapters should work fine in my opinion .
BiggTr is offline   Reply With Quote
Old 11-30-2012, 09:18 AM   #8 (permalink)
Dr.Speed's Avatar
I was able to get that metal plug out when i disassembled them to see what they look like inside. I think I remember them being hollow for at least part of the bar once the metal plug was out.
Old 11-30-2012, 09:33 AM   #9 (permalink)
Duh, I didn't realize that was a plug that could be removed, I thought it was a part of the bar.
Jerry Holland
Old 11-30-2012, 09:34 AM   #10 (permalink)
You will need almost a .75" ID to get the inserts for the mirrors in the bar. I guess you will know when you get the parts in if they fit without drilling.
Jerry Holland
I'm legit now HGaither Twins Talk 8 07-24-2012 08:08 AM
Are these manuals on ebay legit? gribbler Twins Technical Talk 9 03-20-2011 10:08 PM
Legit Survey? VirtualNomad Twins Talk 4 03-26-2009 08:09 PM
British Only- Legit or full of S---? Morris the Cat Classic, Vintage & Veteran 9 02-14-2008 09:20 AM
