98 S3 idling at 1.5k - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Motorcycle.com
Old 11-22-2012, 12:56 PM   #1 (permalink)
Main Motorcycle: 98 Speed Triple T509
bluewater's Avatar
Other Motorcycle: 04 Speed Triple 955i
Extra Motorcycle: 10 Triumph Thunderbird
My bike was originally idling very high (around 3k) so I did some research and found recommendations to replace the ISCV hoses and the throttle body gasket. I did both and now its idling at 1500 steadily.
Any recommendations on next steps? I've seen some of the threads on TuneECU adjustments, etc. but I wanted to throw this specific scenario out there for feedback.
bluewater is offline   Reply With Quote
Old 11-22-2012, 01:03 PM   #2 (permalink)
Legend
DEcosse's Avatar
If the hoses have been replaced and the connections are snug fit, then you probably still have leak at the gasket.
To get that sealed properly, it is best to loosen up the interconnects between the TB's and tighten each one down individually.
Then you are going to want to be sure the balance is good - you will need set of balance gauges for that - can recommend the Morgans CarbTune for that.
Old 11-23-2012, 08:10 AM   #3 (permalink)
bluewater's Avatar
Excellent, thanks DEcosse. I'll give that a shot.
Stumbles when Idling. noopsj74 Twins Technical Talk 6 04-23-2010 09:37 AM
955 idling nycdread Daytona Deliberations 12 02-12-2009 07:21 AM
S3 idling RPM? Crogers Speed Triple Forum 3 09-15-2007 09:59 AM
Idling RPM Healey_100 Club Cafe' 5 09-02-2006 06:30 AM
Idling sangsters Triumph SuperSports 4 08-30-2004 03:50 PM
