Loose rear caliper - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-21-2012, 12:32 AM   #1 (permalink)
Main Motorcycle: 2011 S3 abs
Loose rear caliper
011' s3, is the rear caliper floating or is mine just loose some how? I can move the entire thing (caliper bracket and all) where it mounts around the rear axle....
twistit is offline   Reply With Quote
Old 11-21-2012, 08:02 AM   #2 (permalink)
Main Motorcycle: 2007 Triumph Speed Triple
Ebster1085's Avatar
Search...
http://www.triumphrat.net/speed-trip...-shifting.html
LSL Damper CRG Mirrors OES Sliders CF Frame Covers CF Heel Plates CF Tank Pad CF Rear Hugger Sunline Shifter LED FE Kit MIVV CF Slip On TuneECU K&N Air Filter FH012AA R/R Stoltec Starter Cables The2Wheels Levers Rick's Hotshot Stator
Ebster1085 is offline   Reply With Quote
Old 11-21-2012, 03:53 PM   #3 (permalink)
Ok cool thanks, from that post I gather its normal for a small amount, but my bike only has 6k kms. Not sure what to make of it.
Old 11-22-2012, 01:48 AM   #4 (permalink)
Main Motorcycle: 2010 speed triple 1050 SE
Other Motorcycle: 1981 XT 500
re loose caliper
Think you will find all of the rear calipers do have a little back and forth movement; I know my 2010 does. Doesn't seem to have any rattle on the road and definitely performs well. My only complaint is the amount of brake dust the rear brakes generate. Front brembos seem to have a much better quality pad material. I will be looking for similar compound for the rear next time. Check with your dealer if you are concerned about the caliper play. The bike should still be within the manufacturer's warranty period.
triple303 is offline   Reply With Quote
Old 11-22-2012, 02:01 PM   #5 (permalink)
Main Motorcycle: Speed Triple
Other Motorcycle: Street Triple
Rear brakes 2010s3
I have a 10 model and noticed the rear brake feel strange, discovered disc stuffed and pads gone. This is at 17k. Had service at 10k - not a mention of a rear pad issue. Has anyone had a similar issue.
Ps. I also have a BMW for touring and have done 33k in 9 months with no rear pad issues, so I assume you can't blame it on my riding tech.
Any thoughts helpful as I am taking to the dealer Monday
MarkP is offline   Reply With Quote
Old 11-22-2012, 08:01 PM   #6 (permalink)
Main Motorcycle: '08 S3
Joe Houle's Avatar
Other Motorcycle: '02 S4
Extra Motorcycle: '08 Scrambler
The pins on the rear brakes can become easily fouled and the brakes drag.
SUPPORT THE TROOPS!!
Joe Houle is offline   Reply With Quote
Rear wheel nut loose. Eyore Sprint Forum 7 12-02-2009 10:24 AM
Loose rear brake? dw562714 Triumph SuperSports 3 04-23-2009 01:44 AM
Rear brake lock up & possible Rear Caliper replacement HOwebman Speed Triple Forum 4 09-23-2008 03:33 PM
Loose rear end??? jellero Sprint Forum 15 06-10-2007 04:53 AM
Help! Loose Rear Wheel JMHbb26 Daytona Deliberations 3 03-24-2007 05:46 PM
