09 S3 145mph top speed?????? How???? - Page 7 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 11-27-2012, 12:47 PM   #61 (permalink)
Main Motorcycle: 08 R1200GSA Adventure
onesaintsfan's Avatar
Other Motorcycle: 09 Triumph Speed Triple
Extra Motorcycle: ZX12R ( I wish )
2009 Stock Speed Triple with a 280lb 6'4' rider by the GPS will do 128mph max. Ask me how I know
John M. Hart
McComb MS 39648
2009 Triumph Speed Triple
2008 BMW R1200GS-Adv
2005 Chaparral 210ssi "Proud Mary"
onesaintsfan is offline   Reply With Quote
Old 11-27-2012, 01:03 PM   #62 (permalink)
morvegil's Avatar
I'm 220 and get 145
Sent from my motorcycle while riding.
2012 Speed Triple R
2010 Ducati Streetfighter
2008 Triumph Sprint ST (sold)
2008 Harley-Davidson Night Rod (Sold)
morvegil is online now   Reply With Quote
Old 11-27-2012, 01:20 PM   #63 (permalink)
Main Motorcycle: triumph street triple
jimlowe's Avatar
I lived in Germany when in the armed forces and owned a kawasaki zzr1100,fastest I saw on the clock on the Autobahn was just over 170 mph,wasn't fun just scary.on slight bends the centrifugal force was try to throw me into the barriers,I'm a bit older now and dont think I will be trying to find out how fast my triple is any time soon
jimlowe is offline   Reply With Quote
Old 11-27-2012, 03:40 PM   #64 (permalink)
Main Motorcycle: 2007 Speed Triple
Twisty King's Avatar
Other Motorcycle: 2012 Thruxton
Extra Motorcycle: 2007 Yamaha YZF-R6
Another thing to factor in would be that most speedometers are not correct once you start hitting such high velocity. My Yamaha R6 will tell you that you are going 186 MPH when in fact it tops out at 155 unmodified. My friends CBR600RR is the same. This could be something to consider as well.
Twisty King is offline   Reply With Quote
Old 11-27-2012, 08:09 PM   #65 (permalink)
Main Motorcycle: 2010 Street Triple
bira's Avatar
Originally Posted by 12340987 View Post
without examining the math, I'm having a hard time believing these vehicles with power/weight ratios better than that of some supercars, can't exceed 140. I see posts of people hitting 130 in their stock civics, surely a bike is going to produce less drag than any car? Isn't 140 typically the figure that speed governors are set at?
It's called gearing and wind resistance. Theoretically, the '09-'10 Speedy should do about 168 @ 10,000rpm. However, peak hp is at 9400, I believe. This would mean you'd be hard pressed to hit 10,000rpm in 6th unless modifying the bike to reduce wind resistance. At 9,400rpm you would be going about 158mph, again theoretically, wind resistance may keep you from even getting to that speed.
Modifications so far:
Axxiom valve kit, Traxxion spring kit
CBR600RR shock
Tail Tidy, Triumph bar end mirrors
FP Racing levers, -1 front sprocket
bira is online now   Reply With Quote
Old 11-27-2012, 08:40 PM   #66 (permalink)
Main Motorcycle: t509
Makes it more believable to me when you factor in gearing, I guess. But a 140 hp civic going 130? Just doesn't seem right. Why would god do such a thing?
http://www.9thgencivic.com/forum/9th...our-civic.html
12340987 is online now   Reply With Quote
Old 11-27-2012, 08:42 PM   #67 (permalink)
Main Motorcycle: '06 Speed Triple
Other Motorcycle: '96 Adventurer Cafe Racer
Extra Motorcycle: Not any more
12340987, you might be surprised at the Cd of a naked bike vs a car. The car has more frontal area to be sure, but the Cd is usually so bad on a bike like that this that it makes up for it.
For reference, a typical sedan these days probably comes in around .30 Cd or lower. Examples:
Mazda 6, Honda Civic hybrid, Lexus GS - .27 Cd,
Toyota Camry, Nissan 350Z, Mercedes SL - .29 Cd
Honda Odyssey, Honda NSX - .30 Cd
As you can see, physical size has less to do with drag than you might expect.
I didn't find an Cd numbers for bikes, but I understand they run closer to 1.0 - or 3+times as much drag as a modern car. Open, exposed wheels and no fairings are just bad at parting the air.
Don
'06 Speed Triple
and a bunch of other stuff
If everything seems under control, you're just not going fast enough - Mario Andretti
zelatore is offline   Reply With Quote
Old 11-28-2012, 12:58 AM   #68 (permalink)
Main Motorcycle: Triumph Trophy 3
FoothillRyder's Avatar
Other Motorcycle: '98 Triumph Tiger
Extra Motorcycle: '03 Triumph S3
I remember reading (many years ago) that a well designed racing bike has a Cd of something like 0.7, which is why a modern MotoGP bike will top out at something like 220, even with 250hp.
An S3 (and any other nekkid bike) is going to be much higher than that, so zelatore is not too far off with that 1.0 'guess'.
- FoothillRyder
AMA# 289558, COP#0001, BIR#47
'97 Trophy 3, '98 Tiger, '03 Speedie
My Blog
FoothillRyder is online now   Reply With Quote
Old 11-28-2012, 01:01 AM   #69 (permalink)
Originally Posted by morvegil View Post
I'm 220 and get 145
It isn't so much weight as it is size. The previous poster, at 280lb and 6'4", is putting a lot more 'frontal area' in front of that wind.
- FoothillRyder
My Blog
Old 11-28-2012, 01:49 AM   #70 (permalink)
But the cD of an upright cell phone would be much higher than a boeing 747, which would go faster if attached to my poor little t509?
So do bikes not have speed governors?
2001 Speed Triple or 2003 speed four???? TheBigCat Speed Triple Forum 8 04-26-2010 04:31 AM
