09 S3 145mph top speed?????? How???? - Page 5 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-24-2012, 03:26 PM   #41 (permalink)
Main Motorcycle: '08 S3
Joe Houle's Avatar
Other Motorcycle: '02 S4
Extra Motorcycle: '08 Scrambler
The first time I wound mine out, I was wearing my Arai XD3, bad idea. I felt like the Rocketeer..
SUPPORT THE TROOPS!!
Joe Houle is offline   Reply With Quote
Old 11-24-2012, 05:55 PM   #42 (permalink)
Main Motorcycle: 98 T595
Ahks's Avatar
LoL turning your head made you change direction?
Ahks is online now   Reply With Quote
Old 11-24-2012, 06:37 PM   #43 (permalink)
Main Motorcycle: 2012 Triumph Speed Triple
bradvanhorn's Avatar
Other Motorcycle: 2009 Kawasaki ZX-6R
Extra Motorcycle: 2012 Kawasaki Ninja 250
FACT: At 130mph, I already feel like I have gone to plaid, so I really don't care.
I agree with you on this point. NOLA motorsports park has a 3360 ft main straight and I can only hit about 135 mph before it starts getting pretty uncomfortable. Real track bikes are getting to 150+ mph. Aerodynamics make a huge difference.
bradvanhorn is offline   Reply With Quote
Old 11-24-2012, 07:42 PM   #44 (permalink)
Main Motorcycle: Daytona 600
D6Rider313's Avatar
Other Motorcycle: SV1000s
Ha ha ha, you have some troubles brother.
What can I say, I don't like to wear out my front tires lol
Sent from my HTC One X using Motorcycle.com Free App
D6Rider313 is offline   Reply With Quote
Old 11-25-2012, 12:30 AM   #45 (permalink)
Main Motorcycle: 2012 Speed Triple
mckinney's Avatar
I hate to say this but I can vouch for mine having seen the rev limiter more than once in 6th gear I takes some road but it will get there I can assure you! After 125 it is slower but steadily rising on MPH.
I have ridden with another member here on the forum and I am sure he will say many things about our rides together and taking it easy on the triple would be in that discussion Right Wabbit
FACT: The only way this bike will hit rev-limit in 6th gear, is on a dyno. It does not have the power to push all the way up when she is in the breeze.
also I must respectfully disagree. I am running 18/45, and the bike has a little more "zip", but also is pulled up out of its trouble area of 3500-4500 RPM.
Keep the rubber side down!
mckinney is offline   Reply With Quote
Old 11-25-2012, 01:43 AM   #46 (permalink)
Main Motorcycle: 2006 S3 Fusion White
ScotchS3's Avatar
Originally Posted by DEcosse View Post
I have same config (Daytona motor in S3) but I'm afraid have not taken it to limit. Besides my final gearing is 18:45
Daytona is 29PS over the 955 S3, but 'only' 19PS over the 1050 S3.
Factory quoted numbers in PS are actually 118, 128 & 147 converted to HP respectively for S3 955, S3 1050 & Daytona 955.
I went from the T509 885 engine at 108 PS (106.5 HP) to Daytona motor at 149 (147HP)
But yes, if you want absolute top speed, the Daytona 955 is definitely going to pull on the 1050 S3 when it runs out of grunt (i.e. power limited) - even if both naked
Are you saying the 955 will top out higher than the 1050?
I ride an 06 speedy 1050, my cousin has an 03 955 and I've spent time on both bikes. He can't run with me and I've noticed his doesn't have the hole shot mine does.
We have ran side by side at 135+ and can say that I had room to go.
I am 6'1" 220 and in the gym 4 days a week and at 130 that bike is damn hard to hold on to.
ScotchS3 is offline   Reply With Quote
Old 11-25-2012, 10:29 AM   #47 (permalink)
Joe Houle's Avatar
So it actually hit the limiter and was cutting out, or you looked down and saw the revs over 10k?
Old 11-25-2012, 12:03 PM   #48 (permalink)
Legend
DEcosse's Avatar
I ride an 06 speedy 1050, my cousin has an 03 955 ...
Which 955 does he have, Speed Triple or Daytona? Big difference.
Either way, the 1050 will have a little more torque in the mid-range and should pull better there; at top-end, the Daytona motor with 20Hp more will have higher max speed.
Old 11-25-2012, 01:14 PM   #49 (permalink)
mckinney's Avatar
Wow, I guess I completely blew that one. I did not catch the rev limiter part until now. My bad!
I have hit 10 grand more than once, but not the rev limiter. That we have hit in third and forth but I am not sure about 5th and 6th.
Old 11-25-2012, 01:46 PM   #50 (permalink)
Joe Houle's Avatar
That's what I'm saying about the clocks, they are very inaccurate. The limiter will kick in where ever it's set to. If the clocks are indicating you are over 10k, and no limiter, you are not over 10k
2001 Speed Triple or 2003 speed four???? TheBigCat Speed Triple Forum 8 04-26-2010 04:31 AM
