09 S3 145mph top speed?????? How???? - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.comMotorcycle.com Classifieds!
Old 11-21-2012, 01:15 AM   #21 (permalink)
Main Motorcycle: 05 Speed Triple
Ferris's Avatar
Something is amiss or it's a magic Speedy.
Just tried this out with mine and 3rd gear rev limit = speedo 185kph (115mph) and GPS 171kph (106mph). Gearing is stock!
Ferris is offline   Reply With Quote
Old 11-21-2012, 01:17 AM   #22 (permalink)
Main Motorcycle: '08 S3
Joe Houle's Avatar
Other Motorcycle: '02 S4
Extra Motorcycle: '08 Scrambler
the speedo is off, way off. The bike hits a wall around 130.
If you are really the type concerned about it, then I have no doubt you are going 130 in 3rd.
I bet if you took the plastic mohawk off your helmet, she would hit 160 in 4th..
what I'm trying to say is, you seem a little confused.
SUPPORT THE TROOPS!!
Joe Houle is offline   Reply With Quote
Old 11-21-2012, 01:27 AM   #23 (permalink)
Main Motorcycle: 98 T595
Ahks's Avatar
Dont forget all eight of his arms... those have to be tucked in too...
Ahks is online now   Reply With Quote
Old 11-21-2012, 01:29 AM   #24 (permalink)
Joe Houle's Avatar
good point.
Old 11-21-2012, 03:29 AM   #25 (permalink)
Legend
DEcosse's Avatar
Originally Posted by FoothillRyder View Post
.. Any chance you've checked the 'new' bike ('03 S3 w/Daytona power) with that GPS? Extra 30hp should give you something like 8-10mph? ...
I have same config (Daytona motor in S3) but I'm afraid have not taken it to limit. Besides my final gearing is 18:45
Daytona is 29PS over the 955 S3, but 'only' 19PS over the 1050 S3.
Factory quoted numbers in PS are actually 118, 128 & 147 converted to HP respectively for S3 955, S3 1050 & Daytona 955.
I went from the T509 885 engine at 108 PS (106.5 HP) to Daytona motor at 149 (147HP)
But yes, if you want absolute top speed, the Daytona 955 is definitely going to pull on the 1050 S3 when it runs out of grunt (i.e. power limited) - even if both naked
Old 11-21-2012, 08:12 AM   #26 (permalink)
Main Motorcycle: 03 Daytona powered Speedy
Other Motorcycle: 2002 Tiger
Extra Motorcycle: 1996 Adventurer
Finally, some data. Any chance you've checked the 'new' bike ('03 S3 w/Daytona power) with that GPS? Extra 30hp should give you something like 8-10mph?
I was leaving that one out since it is a wild card, but your close. 150-151 depending. It accelerates harder through the gears (that's why I have it) but its aerodynamically a brick just like the others.
Aunatural is online now   Reply With Quote
Old 11-21-2012, 08:16 AM   #27 (permalink)
Don't know how fast the Tiger goes, it get funky at 110. As for the Adventurer, it's a work in progress and honestly I don't care. There all just as fun at 80 then they are at terminal velocity.
Old 11-21-2012, 10:35 AM   #28 (permalink)
Main Motorcycle: 2010 Street Triple
bira's Avatar
IF you have sufficient power to overcome the aerodynamic drag at that speed.
(just to clarify)
Indeed, you may not even make it to the rev-limiter in 6th gear.
Modifications so far:
Axxiom valve kit, Traxxion spring kit
CBR600RR shock
Tail Tidy, Triumph bar end mirrors
FP Racing levers, -1 front sprocket
bira is online now   Reply With Quote
Old 11-21-2012, 01:05 PM   #29 (permalink)
Main Motorcycle: 2011 WHITE Speed Triple
Its probably limited by reason.
Sent from my HTC Glacier using Motorcycle.com Free App
2011 Crystal White S3
All the R&G bits
Lots of CF bits!
Speedycaptain is online now   Reply With Quote
Old 11-21-2012, 01:34 PM   #30 (permalink)
Main Motorcycle: Triumph Trophy 3
FoothillRyder's Avatar
Other Motorcycle: '98 Triumph Tiger
Extra Motorcycle: '03 Triumph S3
... or it should be
- FoothillRyder
AMA# 289558, COP#0001, BIR#47
'97 Trophy 3, '98 Tiger, '03 Speedie
My Blog
FoothillRyder is offline   Reply With Quote
2001 Speed Triple or 2003 speed four???? TheBigCat Speed Triple Forum 8 04-26-2010 04:31 AM
