09 S3 145mph top speed?????? How???? - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 11-20-2012, 10:40 AM   #11 (permalink)
Main Motorcycle: 2012 Speedie
steve.g's Avatar
Other Motorcycle: 2002 Sprint RS
Extra Motorcycle: Yamaha xs650
Originally Posted by D6Rider313 View Post
No **** Sherlock, if I wanted people to come on here and tell me that air creates more drag at higher speed I would have asked for that, congrats congrats captain obvious.
Now the point is, and the rate its still accelerating after 130 I am stating that it is a physical impossibility for it to top out at 140something 160 seems more likely to me but I guess I'll just have to give it a shot
Sent from my HTC One X using Motorcycle.com Free App
Not trying to be smart. Just answering your original question. Have a nice day.
Over the hill and picking up speed on the way down...!!!
steve.g is offline   Reply With Quote
Old 11-20-2012, 11:50 AM   #12 (permalink)
Main Motorcycle: Speed Triple
Kafn8td's Avatar
I think you are going to be aero limited before it runs out of motor. With my FZ1 on a mile long airstrip, I was aero limited to about 156.
Kafn8td is offline   Reply With Quote
Old 11-20-2012, 12:05 PM   #13 (permalink)
Main Motorcycle: Triumph Trophy 3
FoothillRyder's Avatar
Other Motorcycle: '98 Triumph Tiger
Extra Motorcycle: '03 Triumph S3
Is there really a point here?
Geez... that app says redline in top gear is ~155. So IF you can tuck in tight enough you might see that speed. The thing about aero drag is that it is NOT nonsense! The power required to overcome aerodynamic drag increases with the square of the speed. A 'sit up' motorcycle has a terrible drag coefficient (Cd) as compared to almost any other vehicle, so the aero drag is a huge factor once the speed is up into triple digits.
- FoothillRyder
AMA# 289558, COP#0001, BIR#47
'97 Trophy 3, '98 Tiger, '03 Speedie
My Blog
FoothillRyder is offline   Reply With Quote
Old 11-20-2012, 04:06 PM   #14 (permalink)
Main Motorcycle: 2006 Black Speed Triple
com5984's Avatar
Other Motorcycle: 2004 Gilera VXR200
Extra Motorcycle: 2007 White Speed Triple
lets not forget the gearing
Cheers
Rob
com5984 is offline   Reply With Quote
Old 11-20-2012, 07:11 PM   #15 (permalink)
Main Motorcycle: 2010 Street Triple
bira's Avatar
Originally Posted by Speedycaptain View Post
Use a GPS, speedos are inaccurate.
Sent from my HTC Glacier using Motorcycle.com Free App
Yes, unless you've "fixed" your speedo it's likely off by at least 6% and at that, an indicated 130 is really more like 122. Also, realize that the ratio difference between each gear becomes less and less as you get up in gears. I.e. the speed increase is not a linear, if that makes sense. Speeds gearing is:
1st: 2.73/1
2nd: 1.94/1
3rd: 1.54/1
4th: 1.29/1
5th: 1.15/1
6th: 1.07/1
That's a decreasing, acceleration, slope and in the end, the rev limiter will determine your top speed.
Modifications so far:
Axxiom valve kit, Traxxion spring kit
CBR600RR shock
Tail Tidy, Triumph bar end mirrors
FP Racing levers, -1 front sprocket
bira is online now   Reply With Quote
Old 11-20-2012, 10:52 PM   #16 (permalink)
IF you have sufficient power to overcome the aerodynamic drag at that speed.
(just to clarify)
- FoothillRyder
My Blog
Old 11-20-2012, 11:13 PM   #17 (permalink)
Legend
DEcosse's Avatar
No **** Sherlock, if I wanted people to come on here and tell me that air creates more drag at higher speed I would have asked for that, congrats congrats captain obvious. ...
Keep it civil D6Rider313 - that attitude is not welcome here.
Old 11-20-2012, 11:28 PM   #18 (permalink)
Main Motorcycle: 03 Daytona powered Speedy
Other Motorcycle: 2002 Tiger
Extra Motorcycle: 1996 Adventurer
My 05 Speedy would hit 145 on the GPS. The 07 I had was at 142. My 06 Rocket would just tip 135. It is what it is.
Sent from my XT907 using Motorcycle.com Free App
Aunatural is online now   Reply With Quote
Old 11-20-2012, 11:41 PM   #19 (permalink)
Finally, some data. Any chance you've checked the 'new' bike ('03 S3 w/Daytona power) with that GPS? Extra 30hp should give you something like 8-10mph?
- FoothillRyder
My Blog
Old 11-20-2012, 11:45 PM   #20 (permalink)
Main Motorcycle: 06 Speed Triple
Joemomma's Avatar
Other Motorcycle: 99 SV 650
Extra Motorcycle: 03 WR250F
(just to clarify)
FWIW, the top speed of the SV 650 was a bit faster in 5th gear than in 6th...I couldn't hit redline in 6th with my stock, unpiped, unjetted bike.
Even if you put taller gearing on the S3, you might not get much more, as you may find you can no longer overcome the extra drag. On the type of roads I enjoy riding, that's pointless anyways. Those of you with endless straight roads may differ in opinion.
insert clever saying here...
Joemomma is online now   Reply With Quote
2001 Speed Triple or 2003 speed four???? TheBigCat Speed Triple Forum 8 04-26-2010 04:31 AM
