earlier this summer, all my coolant burped out from the reservoir which I found ... odd. Reading the forums, it seems this is 'normal'.
When I went to replace the coolant, i found this. It smelled horrible by the way.
I performed a flush; the rad bled green and no signs of sludge anywhere else, but the rad cap had a bit. I replaced the coolant but it burped out again. Speed never overheats btw.
Is this a sign of a blown head gasket or something else? Should I not worry about it ?
