Not starting after gassing up - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 11-18-2012, 11:40 AM   #1 (permalink)
Main Motorcycle: 2009 Speed Triple
drsib's Avatar
After two problem-free years with my '09 speedy, I now have a recurring problem. I have 15K miles on her now with original battery.
Unlike other posters, she starts up on first or second try with plenty of gusto, even when idle for a week and garage temp of 50F. The problem has occurred several times now: I stop to gas up, typically don't even get off bike, so takes a couple minutes I guess. I hit start and it starts to crank then stops. After a few attempts, my buddies heads begin to sink, then it fires up and I'm off. Yesterday, no such luck, but I was near a hill and roll started it. (after I learned that this should be done in second gear! I couldn't figure out why my rear wheel was locked in 1st gear). We later stopped a half hour for coffee and she roared to life without problem. I conclude that it is the very brief stop that is to blame...thoughts?
Thanks!
drsib is offline   Reply With Quote
Old 11-18-2012, 12:16 PM   #2 (permalink)
Main Motorcycle: Triumph Trophy 3
FoothillRyder's Avatar
Other Motorcycle: '98 Triumph Tiger
Extra Motorcycle: '03 Triumph S3
Lots of variables here; but my first question is: How do you maintain your battery?
Bikes in general (and perhaps S3's in particular) are very sensitive to the condition of the battery - and the condition of the connections in the charging and starting circuits. If the battery isn't very strong, this kind of thing can happen. The starter draws more current from the battery than does any other single component, which can drop the voltage available to run everything else when the starter is cranking the engine. The ECU requires a certain voltage to do its job, and it is possible that it isn't getting what it needs.
Or... it's always the battery.
- FoothillRyder
AMA# 289558, COP#0001, BIR#47
'97 Trophy 3, '98 Tiger, '03 Speedie
My Blog
FoothillRyder is online now   Reply With Quote
Old 11-18-2012, 12:59 PM   #3 (permalink)
drsib's Avatar
Hmm. I might end up with a new battery, but your reply doesn't explain what I'm experiencing. I have complete confidence that I can walk into garage right now and start her on first or second try. But after four problems after getting gas, I'm looking for downhills and considering leaving my bike running for quick stops. Perplexing, right?
My battery maintenance= riding every week. I put it on tender if I won't be riding. Terminals look great.
Old 11-18-2012, 01:15 PM   #4 (permalink)
Main Motorcycle: 2010 Speed Triple
Jeremy J's Avatar
Other Motorcycle: 2011 Thruxton (Sold)
Extra Motorcycle: 1993 FXRS (Sold)
I don't have a solution for you but you might try searching for "hot start issue" or something similar. I've seen that type of problem on plenty of cars and a few different solutions. Seems like I remember a starter not liking heat on a friends car. He had to sit for 30 minutes after shutting it off or it would just click.
Jeremy J is offline   Reply With Quote
Old 11-18-2012, 01:27 PM   #5 (permalink)
Main Motorcycle: '08 S3
Joe Houle's Avatar
Other Motorcycle: '02 S4
Extra Motorcycle: '08 Scrambler
Put it on a full size charger that desulfates, not just a battery tender. Once its desulfated and topped off, load test it.
SUPPORT THE TROOPS!!
Joe Houle is offline   Reply With Quote
Old 11-18-2012, 02:17 PM   #6 (permalink)
Legend
DEcosse's Avatar
Does it seem like it cranks slow, or either doesn't crank and just clicks?
If the former, battery probably just past its best, assuming the generating system is good (check the voltage across the battery with engine running)
If the latter, look for broken key-switch harness - does situation change if you rotate the bars back & forward or pull on the switch cable harness?
Old 11-18-2012, 04:21 PM   #7 (permalink)
Main Motorcycle: 2011 S3
Do a check for parasitic drain. Do a google search, very easy if you have a decent multimeter. If you think battery is issue.
bevivino1 is online now   Reply With Quote
Old 11-18-2012, 05:59 PM   #8 (permalink)
drsib's Avatar
Damn, I think you may have nailed it DEcosse! Everytime I shut my bike down I turn the handlebars full left and remove key at the locked position. BUT, when I get gas I leave the handlebars neutral.
The "hot start" issue also makes some sense. I still have a hard time with the "bad battery" angle since it starts up easily after sitting for a week.
I'll do some testing...
Thanks for the ideas! (And thank you DEcosse for the group buy on the MOTOMFG stand!)
Old 11-18-2012, 06:00 PM   #9 (permalink)
Other Motorcycle: Honda Hawk GT
Check all your ground connections for cleanliness and tighten. Your condition sounds like a ground fault to me...
jalapenos is offline   Reply With Quote
Old 11-18-2012, 06:03 PM   #10 (permalink)
After sitting for a week (or even an hour) the ECU is nice and cool, and will have different needs vis-a-vis supply voltage than it does after it's gotten nice and hot on a ride. Not trying to defend my point, just providing some clarification.
- FoothillRyder
My Blog
ST3 Not starting - trouble starting murphy379 Street Triple Forum 7 07-11-2012 06:15 PM
starting problems hard starting Fkran Speed Triple Forum 18 01-11-2012 08:33 PM
Gassing Up Woes and Annoyances Vegas_07Bonnie Twins Technical Talk 21 03-05-2009 07:00 PM
Stupid ? of the day. Gassing up my bike. Rob 93ZR-1 Biker Hang-Out 27 09-26-2008 09:03 PM
Hard starting / starting fluid TailHooker Hinckley Classic Triples 20 09-01-2007 12:39 PM
