Not starting after gassing up - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com
Old 11-18-2012, 06:03 PM   #11 (permalink)
Main Motorcycle: 2009 Speed Triple
drsib's Avatar
Originally Posted by jalapenos View Post
Check all your ground connections for cleanliness and tighten. Your condition sounds like a ground fault to me...
Will do! Thanks
drsib is online now   Reply With Quote
Old 11-18-2012, 07:11 PM   #12 (permalink)
drsib's Avatar
Originally Posted by FoothillRyder View Post
After sitting for a week (or even an hour) the ECU is nice and cool, and will have different needs vis-a-vis supply voltage than it does after it's gotten nice and hot on a ride. Not trying to defend my point, just providing some clarification.
Oh! I'm glad you clarified, because I completely missed your point first time round. This would fall into both "hot start" and "bad battery" categories...
Thanks!
Old 11-18-2012, 08:38 PM   #13 (permalink)
Legend
DEcosse's Avatar
After sitting for a week (or even an hour) the ECU is nice and cool, and will have different needs vis-a-vis supply voltage than it does after it's gotten nice and hot on a ride.....
can't see that makes any difference .........
Old 11-18-2012, 10:37 PM   #14 (permalink)
Main Motorcycle: S3
I've had the same problem with my 2010 Speed3. The symptoms were exactly as you're describing: my bike wouldn't start after short stops (typically gas station), but would start fine if left alone for 20-30 minutes. My local Triumph service has finally been able to diagnose the issue, and the problem was: faulty starter drew 180 AMPS when hot. They replaced the starter and starter clutch. All parts were covered by Triumph, I've paid for the labor.
sergey is offline   Reply With Quote
Old 11-18-2012, 10:45 PM   #15 (permalink)
Main Motorcycle: Triumph Trophy 3
FoothillRyder's Avatar
Other Motorcycle: '98 Triumph Tiger
Extra Motorcycle: '03 Triumph S3
Well, here's the deal lad. The ECU has a slew of sensors attached to it, and when the silicon is hot the thresholds are different than they are when it is cold (or cool). The voltage supplied by the battery during the starting sequence - if low enough - could cause some of those 'triggers' not to work as expected. Circuits internal to the ECU might also be affected.
Might not be related; but it's possible.
- FoothillRyder
AMA# 289558, COP#0001, BIR#47
'97 Trophy 3, '98 Tiger, '03 Speedie
My Blog
FoothillRyder is offline   Reply With Quote
Old 11-18-2012, 11:20 PM   #16 (permalink)
Legend
DEcosse's Avatar
Lad? Been a VERY long time since anyone called me that
Sorry FR, but that's just nonsense - the ECM draws well under 1 A - sensors draw at most only a few mA each and electronic components have negligible change in operational specs based in a fairly typical operating range from -40 to 150 C
Old 11-18-2012, 11:24 PM   #17 (permalink)
Main Motorcycle: '08 S3
Joe Houle's Avatar
Other Motorcycle: '02 S4
Extra Motorcycle: '08 Scrambler
dayum. that just happened.
SUPPORT THE TROOPS!!
Joe Houle is offline   Reply With Quote
Old 11-18-2012, 11:35 PM   #18 (permalink)
Legend
DEcosse's Avatar
Originally Posted by sergey
My local Triumph service has finally been able to diagnose the issue, and the problem was: faulty starter drew 180 AMPS when hot.....
Wow - now that would certainly do it
A fairly simple test to see if same problem would be to check voltage across battery when hot, with lights on - if not sagging significantly under 10A load from lights & is measuring over 12V still, measure voltage again while cranking - normal sag while cranking should be in the order of 11.0V with a well-charged battery.
Of course if battery is not fully charged it will sag further, even if starter is normal - the key would be how much it sags with just the lights
Compare your hot & cold voltages for these conditions:
Resting (off); lights/ign on & cranking
Old 11-18-2012, 11:40 PM   #19 (permalink)
Joe Houle's Avatar
A fairly simple test to see if same would be to check voltage across battery when hot, with lights on - if not sagging significantly under 10A load from lights & is over 12V still, measure voltage again while cranking - normal sag while cranking should be in the order of 11.0V
Like I mentioned, desulfate, top off, load test. I'm thinking its a simple tired battery.
10.3v is your magic "no start" number
Old 11-19-2012, 12:39 AM   #20 (permalink)
Legend
DEcosse's Avatar
Sulphated battery would be worse after sitting a week vs just charged off the bikes generating system
The hot vs cold voltage tests above will tell a lot
ST3 Not starting - trouble starting murphy379 Street Triple Forum 7 07-11-2012 06:15 PM
starting problems hard starting Fkran Speed Triple Forum 18 01-11-2012 08:33 PM
Gassing Up Woes and Annoyances Vegas_07Bonnie Twins Technical Talk 21 03-05-2009 07:00 PM
Stupid ? of the day. Gassing up my bike. Rob 93ZR-1 Biker Hang-Out 27 09-26-2008 09:03 PM
Hard starting / starting fluid TailHooker Hinckley Classic Triples 20 09-01-2007 12:39 PM
