Front Brake Lever Comes Back To Grip - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com
Old 11-18-2012, 12:18 PM   #11 (permalink)
Main Motorcycle: 2008 Speed Triple
Location: I live in PA, and the voices live in my head.
Other Motorcycle: Buell XB12R
Extra Motorcycle: SR50 Factory
My experience with Brembo set ups is that you get water in the fluid more than burning it up. I never used blue fluid, but Motul with moisture is orangish. Just look for it to go from milky orange to clear.
If you have air in your lines, here's an easy way to find it. Grab a couple of zip ties, pull your lever until it has some resistance. Tie it open. Go out to your bike in the morning. If your lever has no resistance, you have air.
I accidentally bled some air into my brakes when I changed the fluid in my S3 this summer. I just did the zip tie, hit the master with a rubber mallet, added brake fluid and it's been great since.
As far as a MityVac goes, it's a nice tool, but not necessary. It's really helpful when you're changing brake lines. But just doing a flush, I rather do them by hand.
Edit: If worse comes to worse, pull the calipers and push the pads back in.
tony216 is offline   Reply With Quote
Old 11-18-2012, 02:45 PM   #12 (permalink)
Main Motorcycle: 2009 Speed Triple
jaypeekay's Avatar
Other Motorcycle: Honda XL650R
Extra Motorcycle: Yamaha XT500
Thanks for everyone who posted advice in this thread.
Problem solved!
I bled the master cylinder at the bleed nipple on the handlebar control - lots of air.
5 minutes later, lever rock hard!
Took it out for a spin (with a broken foot) and cannot get the smile off my face.
Pulls like a train, stops on a dime.
God I love this bike - it just gets better and better.
jaypeekay is offline   Reply With Quote
Old 11-18-2012, 04:15 PM   #13 (permalink)
Main Motorcycle: 2011 S3
The brakes on my 2011 S3 are the best I have ever had on 7 bikes I have owned, including the sportbikes.
Congrats on fixing your brake issue!
bevivino1 is online now   Reply With Quote
Old 11-19-2012, 02:30 PM   #14 (permalink)
jaypeekay's Avatar
thanks bevivino1
Front brake lever steve.watts Tiger Chat 11 07-20-2011 05:31 AM
Front break lever touching grip? Stryker Speed Triple Forum 8 07-20-2009 10:39 PM
adjusting front brake lever trav13 Twins Technical Talk 5 07-26-2006 02:16 PM
