11-15-2012, 11:23 AM
Production 125 Main Motorcycle: Speed Triple 2007
won't start in cold weather
Hi There,
I having a problem with my bike, it is not starting after a cold night.
if make it start with my car help and ride to my job (40 min)when I head back home, after 8 hours I have the same problem, i have been replaced the battery for a SHORAI
but i still happening. The cold is that bad yet, is around 40 degree.
the only solution is to bring the battery with me to a warn place.
any advice will help. thanks.
11-15-2012, 11:37 AM
SuperStock Main Motorcycle: 2004 bonneville T100
have you got plenty of anti freeze in the water system?
just drain some water out and top up with anti freeze, cheap to do and see if better after.
11-15-2012, 11:59 AM
Site Supporter SuperStock Main Motorcycle: Triumph Trophy 3
Posts: 289 Other Motorcycle: '98 Triumph Tiger Extra Motorcycle: '03 Triumph S3
Have you contacted Shorai? Seems to me this is some kind of issue with the battery voltage dropping with temperature. What the symptoms when the bike won't start?
- FoothillRyder
AMA# 289558, COP#0001, BIR#47
'97 Trophy 3, '98 Tiger, '03 Speedie
My Blog
11-15-2012, 12:01 PM
Check out the "charging system diagnostics" sticky at the top of the site. And I have read that Shorei batteries don't do well in cold temps.
11-15-2012, 12:14 PM
no, i didn't contact them, but i went to triumph, New York, where i bought the battery they test it and it was full of charge.
if it doesn't start in the first try the battery doesn't have enough for the follow ones but if the battery is in a warn place i will have a long ignition and eventually will start.
11-15-2012, 12:58 PM
Site Supporter Legend Main Motorcycle: Custom 955 Speed-Tona
Posts: 13,289 Other Motorcycle: Suzuki SV650S
That is unfortunately typical signature of LiFePO cells to be immobile at low temperatures
It sounds counter-intuitive, but turn on your ignition/headlights for 30 secs - a minute before attempting start - the battery will 'self-heat' from the 10+ amps it is supplying the lights. This will NOT drain it further, it will improve the situation.
Which size battery did you get - 14 or 18?
The 18 is really a better choice, worth the extra cost.
11-15-2012, 02:15 PM
i didn't have the 18 option, i just placed the order of one of those.
I will try the 30 sec-1 min thing.
Thanks.
11-15-2012, 02:17 PM
Formula Extreme Main Motorcycle: 2011 WHITE Speed Triple
Exactly, you have to heat that battery, and your lights will do it. That is standard with the Shorai. I have th 18, not the 14... You gotta get current flowing.
Sent from my HTC Glacier using Motorcycle.com Free App
2011 Crystal White S3
All the R&G bits
Lots of CF bits!
11-19-2012, 01:08 PM
Stator Coil
Now with the new battery after 10 min trying my bike start.
some friends told me that i should check the stator coil.
thought?
11-19-2012, 02:34 PM
Stator coil will have no affect on ability to start - you can disconnect charging system altogether and if battery is good will start - just will be on total loss and discharge from there on without the generating system.
What was it doing during that 10 mins? Cranking but not starting? Cranking at strong speed or slow, lazy?
