How should my S3 run at low speed? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-14-2012, 10:35 PM   #1 (permalink)
Main Motorcycle: 2010 Speed Triple SE
Hi Guys,
I'm after honest feedback as to whether the S3 should be smooth at lower speeds. Or "that's just the way the bike is" !!!
Sitting at constant speed anywhere between 40-70 kmh (25-44mph) it feels a little jerky. Like going over a small bump every 1-2 seconds. Nothing too concerning, but annoying enough considering a performance machine. Pull clutch in and coast and the issue goes away.
The service dealer (two different ones) both give me "the computer says no, that's just the way it is" answer when I ask if there's anything wrong.
Is this really just the way S3's are? and it's a matter that they're tuned for higher revs/speeds? Or do I need to go back with some ammo and state my case again?
Any help appreciated.
Thanks,
Jimmy
JimmyDee is offline   Reply With Quote
Old 11-15-2012, 12:44 AM   #2 (permalink)
Main Motorcycle: 1050 Speed Triple
Mines crap at low speeds too!
Bones1970 is online now   Reply With Quote
Old 11-15-2012, 12:47 AM   #3 (permalink)
Main Motorcycle: t509
Just the way it is??? Any street bike should be smooth at those speeds. Does the bump sensation match RPM or speed only? Does engine load affect it: high/low throttle, acceleration or deceleration?
I would have had someone there ride it.
However, there is a point where the transmission and engine are at close but not the same rotational speed, so you get this annoying chatter because of gear slop. Happens in any manual transmission vehicle, especially if it's old, which is all I've ever had.
12340987 is offline   Reply With Quote
Old 11-15-2012, 02:46 AM   #4 (permalink)
Main Motorcycle: Speed triple 955i
Yep it's the furling at low speed drop back in to first or second and you'll be fine I travel from north to south manchester uk everyday in rush hour so it works for me ��
CrashHappy is online now   Reply With Quote
Old 11-15-2012, 03:31 AM   #5 (permalink)
Main Motorcycle: Speed Triple (2011)
Mines like that, I had put it down to my floppy wrist (an old masturbation injury )
Around town I knock it up a gear and keep the revs low to smooth it out.
"Time flies like an arrow, fruit flies like a banana"
brumfitt is online now   Reply With Quote
Old 11-15-2012, 05:12 AM   #6 (permalink)
Main Motorcycle: 2003 Speed Triple
PhilM's Avatar
How may RPM's are you running when this occurs?
Probably needs to be kept to at least 3000-3200 or higher depending on load.
PhilM is offline   Reply With Quote
Old 11-15-2012, 09:42 AM   #7 (permalink)
Main Motorcycle: 2000 Speed Triple
chronos71's Avatar
Other Motorcycle: 2003 America (sold)
Have they checked the chain and sprocket? Mine was like that when I bought it used so I took it to the dealer asking the same question. Someone rode it and said the chain was in bad shape. Changed the chain and sprocket and it smoothed out a lot. Might be worth having it looked at.
The quickest way to a man's heart is with Chuck Norris's fist.
chronos71 is online now   Reply With Quote
Old 11-15-2012, 03:33 PM   #8 (permalink)
Main Motorcycle: '08 S3
Joe Houle's Avatar
Other Motorcycle: '02 S4
Extra Motorcycle: '08 Scrambler
How is your bike set up? A lot of the low speed snatchiness has to do with the points at which the mapping is changing tables..Try a different tune.
SUPPORT THE TROOPS!!
Joe Houle is offline   Reply With Quote
Old 11-15-2012, 05:43 PM   #9 (permalink)
Main Motorcycle: 06 ST, BOTM, 09-10 BOTY
oldndumb's Avatar
Other Motorcycle: 05SV1K, 2012 Ducati M1100
Probably Bingo.
Joe is referring to TPS to MAP transition point/switch. You can verify this via TuneEcu.
Oldndumb
Caveat lector
Old 11-15-2012, 05:56 PM   #10 (permalink)
Main Motorcycle: '11 Speed Triple
Moogs's Avatar
Other Motorcycle: '13 Mag Wheel Bonnie
Originally Posted by oldndumb View Post
Probably Bingo.
What value in TuneECU shows this and what is an acceptable value?
Whomever said all good things in moderation certainly never rode a bad ass Bonneville
Moogs is offline   Reply With Quote
2001 Speed Triple or 2003 speed four???? TheBigCat Speed Triple Forum 8 04-26-2010 04:31 AM
